Question about Kenmore 22422 Top Load Washer
Lid switch assembly
THE LID SWITCH ASSEMBLY FELL APART WHEN I CHECKED THE SWITCH. I JUST NEED TO KNOW HOW IT GOES BACK TOGETHER. THANK YOU ROB. ALMOST FORGOT ITS A KENMORE WASHER. MODEL# 110.81661100 ITS A OLD MACHINE, AROUND 30 YEARS OR SO.
  • 318 Answers
Go to www.searspartsdirect.com for a picture of this units lid switch.it doesnt show it very well, but it will give you an idea of how it goes back together.
what you need to do is put the lever around the switch first, then put the plastic box on the switch and arm. then carefully hold the assembly together and try to get it under the top and put the 2 screws back into the housing holes.
it sounds simple but i have done this before and its not easy. you just need to be careful to get the screws into the mounts correctly or it wont hold together to allow the switch to activate when the lid is closed.
by the way was there a reason you took the switch off??
maybe because it wont spin?
by the way this unit is not 30 years old, maybe 20 at the most.
the drive couplings are a weak spot for these and you may have a broken one. it wont spin or agitate but will drain if this is broken.
Posted on Jan 31, 2009
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
Nov 18, 2012 | Maytag Centennial MTW5800TW Top Load...
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Dryer door switch assembly. how do I put it back together
All the terminals should be different in size with the big terminal wire being common which goes in the middle the other 2 wires make the light come on and make the motor go so if you get em backwards she will run with the door open and the light will come on with the door closed..
Aug 29, 2012 | Maytag Dryers
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Jun 03, 2012 | Whirlpool Washing Machines
Sun roof won't open, but i hear the motor turning
Check for any obstruction in the rail.
Also, can check this procedure to test your components...
Power Sunroof - REMOVAL & INSTALLATION (click over pic for zoom)
Motor
See Figure 1
  1. Remove the sunroof switch panel by pushing it to the side and disengaging the pawl, then pulling it downward.
Fig. 1: The sunroof switch panel is retained by a metal clip
  1. Remove the sunroof switch bracket.
  2. Unplug the sunroof motor wiring harness connectors.
  3. Remove the sunroof motor mounting screws.
Disassembly of the sunroof motor is not recommended.
To install:
  1. Lightly lubricate the drive gear with grease and install the sunroof motor to the sunroof assembly.
  2. Plug in the electrical harness connectors to the sunroof motor.
  3. Operate the sunroof to verify proper operation.
  4. Install the sunroof switch bracket and the sunroof switch panel.
Sunroof
See Figures 2 and 3
Fig. 2: Exploded view of the sunroof assembly on 1993-94 vehicles
Fig. 3: Exploded view of the sunroof assembly on 1995-97 vehicles-1998 models similar
  1. Tilt up the sunroof lid.
  2. Remove the lid side trim.
  3. Remove the lid bolts and the lid assembly.
  4. Remove the rear drain mount screws and the drain.
  5. Remove the shade assembly holders from the sunroof frame.
  6. Remove the shade assembly.
  7. Remove the sunroof switch, interior accessories and headliner.
  8. Remove the switch bracket.
  9. Remove the motor assembly, spacer and clip.
  10. Remove the wind deflector mount holders from the sunroof frame.
  11. Remove the wind deflector.
  12. Disconnect the drain hose.
  13. Remove the sunroof brackets.
  14. Remove the sunroof frame assembly.
  15. Remove the link and wire assemblies.
To install:
  2. Install the link and wire assemblies.
  3. Install the sunroof frame assembly.
  4. Install the sunroof brackets.
  5. Connect the drain hose.
  6. Install the wind deflector.
  7. Install the wind deflector mount holders on the sunroof frame.
  8. Install the motor assembly, spacer and clip.
  9. Install the switch bracket.
  10. Install the sunroof switch, interior accessories and headliner.
  11. Install the shade assembly.
  12. Install the shade assembly holders on the sunroof frame.
  13. Install the rear drain mount screws and the drain.
  14. Install the lid bolts and the lid assembly.
  15. Install the lid side trim.
Hope helps (remember rated this help).
Jun 03, 2010 | 1996 Nissan Maxima
Lid Switch
HI, The part# is 3949238. There are two ways to replace this switch. The easiest is to remove the two screws holding the lid switch. Pull the switch out enough that you can clip the wires at the switch. Cut the harness off of the new switch leaving enough wire to put wire nuts on connecting them together.
The other way to change the switch is to remove the cabinet. Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can see the lid switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Apr 20, 2009 | Whirlpool LSR6232J Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
