Question about PfaFF Creative 7570
Sticky clutch older pfaff 7570
When filling a bobbin the clutch does not disengage. The needle goes up and down. When it does disengage the bobbin runs at high speed and will only stop when I push a button on the machine.
I explained this problem to the technician at the sewing machine shop. He said the clutch is dry.
How do I access it? What does it look like? What do I need to do to oil it?
    New Friend:
  • 186 Answers
To fix this yourself you need to remove the handwheel screw and cover. Warning: the mechanism may explode and only an experienced technician can help you put it back together.
1. Remove with a small screwdriver or any small prying instrument the small cover on the middle of the handwheel (it is about the size of a quarter). You will see a silver phillips head screw that is really wide for its size.
2. With a phillips screwdriver remove the screw you see, do not let plastic part underneath move, hold it in so only the screw and washer are removed. (There is a fiber washer underneath that may stick to is or stay behind, remove it with the screw.) It will take a little effort to break it loose and you need to hold onto the handwheel or block the needle bar with something. (remove the needle and place a piece of wood or a book or anything that is about 1" tall under the needle bar and turn the handwheel in the sewing direction until motion stops).
3. Tricky part: You have now removed the screw and washer and hopefully nothing else has come out or sprung across the room. Gengly pull the entire handwheel assembly away from the machine only a fraction of an inch. Pull on the outer part of the handwheel NOT! the inner part (see above re: springs landing on the other side of the room). You are looking at the upper shaft in the center of the assembly, apply a couple of drops of oil to the interface between the plastic handwheel and the shaft (tri-flow is best, but any light weight oil will do, even WD40 if you can stand the smell).
4. Reset the assembly and install the screw/washer/cover.
5. You may still need to block the needle bar and run the machine to work in the oil.
Notes: If you have not have your machine serviced in awhile this may be red flag telling you that it is time. I have worked on Pfaffs for 10 yrs. they are awsome machines but need a little tlc now and then to perform to maximum
Have fun!
Posted on Jan 29, 2009
Pfaff 7570 needle hits with ruffler installed
then quit ruffling LOL I know not funny can not think putting it on changes the place where needle goes down
Aug 30, 2015 | PfaFF Creative 7570
When filling bobbin, needle continues up and down.
You are not in the bobbin winding mode. Check your manual, usually you have to slide the bobbin case over to a post or on real old models, do something on the wheel.
Nov 22, 2014 | PfaFF Creative 7570
Neddle hits bobbin case while sewing zig-zag stitch on Pfaff 7570
insert the needle all the way up or, lift the needle shaft or readjust the timing
Aug 05, 2014 | PfaFF Creative 7570
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
My machine just hums, nothing works
Hi Rita... disengage the bobbin winder feature. :)
Jul 24, 2012 | PfaFF Creative 7570
How do I fill the bobbin?
place the bobbin the winder pull the thread from the spool around tinchoner wrap around bobbin push bobbin against stop turn leaver on wheel to release needle push down on peddle it will auto stop when bobbin is full.
Jul 01, 2012 | PfaFF Creative 7570
I don't have the manual for my machine and am having trouble winding the thread onto the bobbin. Is there any visual help online for this?
I don't know of any web video, but you may have simply forgotten a step. Guide the thread from the spool to the left and under the little tension disk, then to the right. The bobbin should not be turning freely, but have a little pin holding it, then push the bobbin to the right to disengage the motor function for the needle and disengage the flywheel. Hope that helps.
Dec 31, 2010 | PfaFF Creative 7570
My pfaff 1215 won't disengage when filling the bobbin. the needle still goes up and down
The problem is lack of oil underneath the balance wheel on the shaft, if you do not have an oil hole you would be advised to take it in for a service because the balance wheel needs to be pulled out slightly to oil it.
Oct 16, 2009 | PfaFF Sewing Machines
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Jun 16, 2008 | PfaFF Creative 7570
Pfaff Creative 1371
Did the machine get dropped, or otherwise roughly handled? Or have a rough, bumpy ride back home, etc? That could explain why it's not working correctly.
Feb 25, 2007 | PfaFF Creative 7570
Sewing Machines Logo
496 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
