Question about RCA F32444 32" TV
CHANGING CHANNELS ALL THE TIME
MY TV ALL OF THE SUDDEN STARTED CHANGING CHANNELS BY IT SELF WE HAD TO UNPLUG IT FOR IT TO STOP THEN WE HAD A HARD TIME GETTING IT TO COME BACK ON .WHEN YOU DO GET IT ON ALL THE TV WILL DO IS PLAY NORMAL FOR A MINUTE OR TWO THEN KEEP GOING THROUGH ALL CHANNNELS UNTIL YOU CAN GET IT TO TURN OFF OR JUST UNPLUG. NEED HELP
  • 4 Answers
I have seen some RCA TV's with this problem and it has usually been a switch going bad on the keypad of the tv. This can be confirmed by disconnecting the plug from the control panel to the main chassis.If you are lucky, and the ir rcvr for the remote is not on the control board, you can still control tv with the remote.Good luck.
Posted on Jul 26, 2007
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Dec 14, 2015 | Televison & Video
Watching tv and all of a sudden it starts flipping through the channels and won't stop
If you have _no antenna_, make sure the menu (for channels) is set to either ''cable'' or ''satellite''. The TV needs to _know_ there are no ''antenna'' channels to scan for.
If the above doesn't work, try unplugging for a _full_ 24 hours. Then plug in, turn it on, go directly into ''menu'' and do like I stated above.
Note: ''Capacitors'' can ''hold memory'' for a long time. That is why ''unplug for full 24 hrs.''
May 18, 2015 | Westinghouse 32 Flat Screen 720p Hd Led...
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
2005 32-inch GE color television--the problem is all of a sudden the television turned on by itself and started changing channels like crazy--we cannot stop it. When you first turn on the television--it...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 22, 2017 | GE 32GT720 32" TV
I have a rca g36705 36" all of sudden it started changing channels all by it self and it would shut off until i unplugged now it won't turn on
I have the same T.V. with the same problem and I talked to a local guy that use to work on t.v's and he told me that it was the part that plugs into the board in the back ,where the off & on buttons are. I took it apart and he was right .I just need to find out where to get the part
Mar 27, 2011 | RCA G36705 36" TV
Is a Insigna TV, it turns on by it self and starts changeing channels and I can't stop it I have to unplug it.
the problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Televison & Video
Sudden channel changing,flipping off and on and channel searching
Apr 21, 2017 | RCA F36649 36" TV
Denon Receiver keeps changing channels
hello my friend this is happening cause you have a push in button,disconnect from ac take a near look and push the reset button you must check your remote too saludos
Dec 12, 2008 | Denon AVR-2807 Receiver
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
RCA F32444 32" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
