Question about RCA RT2660R Receiver
HOW TO MAKE THE TV AND DVD WORK WITHOUT DISCONNECTING ONE
I HAVE THE RCA 2770, AND I CAN NOT FIGURE OUT HOW TO MAKE THE DVD AND TV PLAY WITHOUT UNPLUGING ONE OR THE OTHER
  • Koreanainusa May 11, 2010
    The Question is Very Unclear but...
    Is RCA 2770 a TV? (Need Full Model Number)
    Is DVD has RF out (Antenna out)? (Need Brand and Model)
    Is RCA has AV inputs?
I'm assuming you are wanting to send signals from two components into one input on your amp? If so you would want to split your signals with a "Y" adapter.
As to the previous poster, it is a HTIB.
Posted on May 03, 2009
How do I get dvd's to play on a 1990's model RCA tv without a tv remote?
You need an RF modulator and the proper cable(s) so that the DVD player can connect to the old TV coax input. See this video for the procedure.
TVs DVD Players How to Hook Up DVD Player to TV Having Only One RF or...
May 09, 2016 | RCA Televison & Video
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
Unable to get remote to switch to tv/video RCA remote tv is sanyo
It took me forever to figure it out. Press the input key, just below the 9. The TV channel should be on 3. Make sure you put your DVD in and press play manually, so you can see that it is on.
Hope that helps
Apr 03, 2009 | RCA 3-Device Universal Remote with...
Unable to make the tv and dvd player work with the rca 2770 home theater system without unplugin one or the other
I assume that you need more input jacks than your receiver offers. You can buy a a/v selector (its an A/B switch for audio and video), so you can switch between input devices. You can get them at Radio Shack on check on the web.
Jan 28, 2009 | Audio Players & Recorders
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
Dvd without coaxial, old tv without RCA, passthrough VCR died
http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
Jan 04, 2009 | Televison & Video
Disney princess tv/dvd not working
conect rca cable 2 av input
Dec 25, 2008 | Disney 13" TV
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
RCA RT2660R Receiver Logo
61 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
