Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Icemaker Input leaks
I have a Whirlpool refrigerator ED5NTQXKQ00 that leaks where the feed line hooks to the refrigerator. It appears the connection might be corroded. If that is the case can I replace this part?
  • 1,214 Answers
Yes, you can replace the part. It's the water fill valve.
But take the line off the connection first and make sure the valve is corroded too severely. It may be that you can just redo/replace the fittings cut the line back a little on the house side water line.
Posted on Jan 28, 2009
Whirlpool fridge freezer no water getting through to icemaker
Check the line going from the back of the fridge through the freezer wall. Sometimes you can get a chunk of ice in the line. Also, did you check to make sure the solenoid valve works? Disconnect the solenoid valve outlet and when there is a demand for water, it should click and water should flow
Jan 14, 2018 | Whirlpool Refrigerators
How do i make my icemaker work
If it came with the refrigerator then everything is hooked up with the exception of the water line in the back, which if you go to home depot you can ask for a stainless steel icemaker line and they'll get it for you. Then all you have to do is connect one end of the line to the faucet if there is one, and the other end to the valve which is at the lower right or left hand side, normally on the right if your standing behind it. Now if there isn't a water connection behind the fridge your going to have to locate a water supply and then when you get the icemaker line tell them you need a installation kit.
Apr 30, 2012 | Whirlpool Refrigerators
When the water line is hooked up to the back of fridge and the line is turned on the refrigerator leaks water out the ice dispensor and does not shut off the flow of water to the fridge.Thus causing it to...
the water soliniod maybe clogged with calcium. if you get it loose you can take the plastic hose loos from the icemaker side of the water valve see if it is dripping or running out of there. if alot is coming out maybe getting voltage too long from the icemaker. it will be one or the other.
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge was leaking from the back... now the ice machine wont work. What could be the problem
ice line is froze and came apart from ice machine usally happens when there is not enough air flow try pulling fridge from wall 2 inches
Oct 01, 2009 | Refrigerators
Icemaker not working
The problem is the solenoid or dual valve is leaking and when that water goes inside the freezer freezes up , this valve has to be replaced.
Sep 27, 2009 | Whirlpool Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
May 23, 2009 | Whirlpool GD2SHGX Refrigerator
Water shooting out the icemaker hose
(I hooked up the lines and water goes heywire) You hooked up the lines to what? If you changed the water valve you may have the dispenser and ice maker lines reversed along with the electrical connections to the top of the valves.
May 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
