Question about Audiovox VE926 9 in. Portable Television
Buttons do not work as the book indicates
When in TV mode, pushing the set button does not bring up a Menu. I do get a menu in the DVD mode. Pushing the set button in TV goes from steady to blinking display only. It will not let me select TV std etc but is in the A mode. The off air antenna is what I am trying to get to work and it seems to require considerable signal to lock so you can see any picture at all. Is there a way to reset the software? Thanks for any help. LarryB227
    Problem Solver:
  • 15 Answers
THERE IS AWAY YOU NEED THE SERVICE MENU OF YOUR TV COMING FROM THE MANUFACTURER
Posted on Aug 27, 2007
SOURCE:
RESET DRUM
TRY THIS
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%
Jul 22, 2014 | OKI C5650n LED Laser Printer
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
How do i change the clock on a 06 Nissan Lafesta, manual is in japanes
Hope this helps
If you are talking about the clock on the DVD display then.....
Audio display model
1. Turn the audio unit on by pushing the "PWR"
button.
2. Push the "MENU" button until the display
indicates the clock adjustment mode.
If the "CLOCK OFF" is indicated on the display,
push the "TUNE" button to change the mode
to "CLOCK ON". Then push the "MENU" button
The time indicator will flash.
3. Push the "SEEK TRACK" button to adjust
the hour.
Push the "TUNE" button to adjust the
minute.
Pushing the , buttons will advance
and , buttons will turn back
the time.
4. Push the "MENU" button to finish the
adjustment.
May 24, 2014 | Cars & Trucks
Vizio worked fine yesterday. today get "unable to launch com.yahoo.widgets.tv.container" when pushing the VIA button
Funny, same thing happened to me about the same time! Took me a while to figure out how to fix it. You have to get to the HDTV Settings menu and hit the Help icon. Do a Clear Memory/(Factory Default) and go thru that process, basically you go through all the settings just as you did the first time you powered up the TV. This will fix your problem.
The challnge is...how to get to the HDTV Settings menu when your VIA button only brings up the error you described? I finally got there like this: Hit the "Input" button on the remote, navigate to "TV" and hit OK (basically just select TV as your input), hit the Menu button on the remote and that will bring up the HDTV Settings menu and then proceed as above
Mar 25, 2011 | Televison & Video
Fuser reset
8. Restart printe
Sep 16, 2010 | OKI C5510 MFP All-In-One Led Printer
Fatal error 980
8. Restart printer.
Thanks,
Bhautesh.
Aug 21, 2010 | OKI C5500n Printer
What is 173:fatal error on my oki c5700?
8. Restart printer.
Jul 01, 2010 | Office Equipment & Supplies
Oki C6100 Laser Printer drum reset - from Fatal
8. Restart printer.
Feb 09, 2010 | OKI C6100n Laser Printer
Stuck in Menu and remote locked out
You may want to change the batteries in the remote and reprogram it. Let me know if that works. kim
Sep 01, 2008 | Symphonic ST420FF 20" TV
Audiovox VE926 9 in. Portable Television Logo
100 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
