Question about RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
Rca D52W19 will not turn on the power light will come on blink 4 times then go off but the tv it's self will not come on
  • 1 more comment
  • senditojacob Feb 02, 2009
    my 52 inch RCA model #D52W19 will not come on. when the power button is pressed the green light flashes then it makes some static noise
  • Anonymous Feb 02, 2009
    same here
  • lecram Feb 19, 2009
    when i press the power button the green light flashes 3 or 4 times but wont come and give a click click sound
  • RCA Master
  • 5,138 Answers
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Posted on Feb 14, 2009
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 when tv turn on the power light blink 3 times but nothing hapen
Cp150, CP120 and CP114 repair kit form www.tvrepairworld.com should solve that issue. The kit comes with the instructions on CD.
Nov 19, 2009 | RCA D52W19 52" Rear Projection Television
When tv turned on the power light blinks 3 times then shuts off tv never comes on
The CP150 CP120 and CP114 repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Oct 14, 2009 | RCA D52W19 52" Rear Projection Television
TV will not turn on
Replace the CP150 CP120 and CP114 capacitors. You can get the repair kit for your RCA at the following link www.tvrepairworld.com The kit contains the capacitors and CD with detailed instructions
Sep 05, 2009 | RCA D52W19 52" Rear Projection Television
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Power button blinks 3 times
You need to replace the flyback, and that will fix your set. You can get a replacment flyback at the following link and they will provide free online instant messaging when you do the repair so they can take you through the replacement step by step. You need flyback number 259296 heres the link.
Aug 08, 2008 | RCA D52W19 52" Rear Projection Television
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
335 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
