Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The compressor on my Sears Coldspot is running at 175 degrees.
Model 63141. Everythings runs fine and is plenty cold, but I noticed the compressor was hot when I last cleaned behind the unit. Is this a fire danger? What is the correct temperature of a compressor? Thank you.
    President:
  • 1,214 Answers
Refrigeration compressors used in domestic refrigeration are known as high side compressors, meaning the dome is at high side pressure and temperature.
As long as the condenser fan was running, and the coil was as clean as you could get it, then all is OK. There is no standard temperature that it runs at, and it has been tested to run hot anyway. The fact that you cleaned underneath will allow it to run a little cooler anyway.
Posted on Jan 28, 2009
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
Kenmore Coldspot mod 106 refrigerator shut down 2 weeks ago,started on its own 4 days later,3 days after that dead again
could be several problems, i would begin by checking to see if the compressor is actually running, if it is you will feel heat and vibration, if not running check the defrost timer or the compressor start device. if you are unfamiliar with what i am asking, call for service.
Sears offers a Service Smart Agreement for around 300 that will include necessary repair now and 1 yr warrenty.
Jan 08, 2012 | Refrigerators
My GE Bottom Freezer Refrigerator Model:PFS22SBSSS The Refrigerator is not cooling, however the Freezer is mantianing proper temprature at 0 degrees. The temp on the fridge is reading 60 degrees on the...
Your problem is almost surely caused by the failure of the fan that should circulate cooled air from the freezer section to the refrigerator. If you check for vents, normally in the rear of the fridge, and hold your fingers in front of them while you hear the compressor running, you should easily feel cold air coming from them if the fan is running.
To determine whether you want to have it serviced or replace the fan yourself, try entering your model number on the Sears PartsDirect website to see if your unit is one of thousands of non-Sears appliances in their library. If they do, then you will find an illustrated parts drawing with part numbers.
Sears PartsDirect
Sep 06, 2010 | GE PFS22SBSSS Stainless Steel French Door...
I own a Kenmore Coldspot 106.71182101 and the refrigerator is now warm while the freezer is perfectly cold and holding it's temp. What can I do about the refrigeratornot being cold?
A common problem; the fan which should circulate some of the cooled air into the fridge is not running. You can verify this while the compressor is running by wetting your fingers and holding them near the vents in the back of the refrigerator. If you cannot detect any air flow, the fan is dead.
Go to Sears parts website and enter your model number. Especially since it is Kenmore, it should bring up a line-drawing and parts list for your model.
Sears Parts Direct
You can then decide whether it is accessible enough for a DIY replacement or if you would rather call a service company to replace it for you. Check with your local BBB to pick a reliable service company.
Aug 04, 2010 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore coldspot #59597993
Check the condenser where heat is removed from the system. Look under the front behind the toe plate under the door. Use a vacuum crevasse tool to get into the narrow places to draw out the dust and lint. Make sure the fan under the refrigerator is running. You can remove the bottom panel in back to observe the fan operation. Listen for sounds at the back like a hum and a click. Check the compressor to see if it is hot and running. If the compressor is cold you may have a control problem.
Jun 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
147 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
