Unable to make the tv and dvd player work with the rca 2770 home theater system without unplugin one or the other
  • 336 Answers
I assume that you need more input jacks than your receiver offers. You can buy a a/v selector (its an A/B switch for audio and video), so you can switch between input devices. You can get them at Radio Shack on check on the web.
Posted on Jan 30, 2009
Can you use dvd without speakers
Yes, go to your Television menu and system settings, select sound source and set it to internal speakers
Feb 15, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
I have a RCA RT2870A that i need a manual or help hook it up to TV and DCD
This is the manual for the 2770 from RCA.com http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
If it has the same inputs as yours, you need an "optical" cable that will go from the TV "output" to the RCA system "optical input" and a "Coaxial Digital" cable from your DVD player to the "Coaxial Digital input of the receiver. Not knowing what kind of TV you are hooking this up to... If it's and LCD,Plasma, or Digital TV, it will have an optical audio out. if it's not one of these, post the model number of your TV & I'll check it. If you are using Cable TV/Satellite or FIOS, Great! then you can run the optical cable from the back of the cable box to the receiver. If you need any more help, just post a comment and I can help you some more.
Jun 23, 2009 | RCA RT2300 System
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Won't work with my tv
You need to connect a Audio video cable (Red/White/Yelloe) from the TV out on you TV set to the approriate input in your DVD player
Oct 09, 2008 | RCA RTD120 System
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
35 people viewed this question
 Grubhead
Grubhead
