Question about LG VX8350 Cellular Phone
I lost the little plastic cover that keps dust and debris out of the port that the charger plugs into on my LG VX8350 portable phone. Can I buy a replacement?
    Problem Solver:
  • 17 Answers
I've had my phone for over 1 yr without that little thing. Never had a problem. Call local Verizon store they can tell you.
Posted on Feb 25, 2009
Broken charger
if it is a broken charger, buy a new charger
if it is a broken charging port, get a universal battery charger
if your battery is swollen or showing water damage, buy a new battery
also check the battery date code, cause batteries expire after a while and this phone is on the older side
Feb 06, 2014 | LG VX8350 Cellular Phone
I lost the instruction manual
Here it is:
http://www.retrevo.com/support/LG-VX8350-Cell-Phones-manual/id/3822dj894/t/2/
Aug 08, 2011 | LG VX8350 Cellular Phone
I have the Verizon LGVX8350R phone, it works perfectly but the only thing is that it will NOT charge, I just bought a new charger from walmart 3 weeks ago so its brand new. I did drop the phone on a...
Hi, you will have to test for both to be sure which is faulty.
You can use another charger to test if it will charge or you can use the charger on another Verizon phone to check if the charger is working.
After that, if the charger works, that means the charging port that you attach the charger to the phone will be the problem.
You will need to replace the charging port.
Take care.
Jun 22, 2010 | LG VX8350 Cellular Phone
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full...
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Oct 13, 2008 | Lands Phones
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
LG PORT
its on the side u have to kinda use ur nail to dis it out it has like a little picture of a plug n u pull it out n plug in the charger hope it helps
Aug 16, 2008 | LG Shine KE970 Cellular Phone
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
LG VX8350 Cellular Phone Logo
83 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
