Question about IBM 08K4800 Keyboard for Thinkpad 560Z, 600 Series Laptops
I type a letter a number pops up as th letter
    Brigadier General:
  • 5,158 Answers
You have the number lock on ... try tapping fn and nm at the same time (once)... that should shut it off
Robert
please take a moment to rate this solution thanks
Posted on Jan 28, 2009
I have an RCA Voyager III RCT6973W43. Every time I go to type on the keyboard, I go to type a word/letter and instead for an example: I'll type a letter like "w" number 2 er comes up.
Borrow a keyboard from a friend. If it still does it then there is something strange with your computer. If it does not do it then your keyboard may be corrupt so buy a new one
Oct 20, 2017 | RCA Computers & Internet
My harddrives cd image partition is readable but another 1tera byte part is not getting detectd. please help
Sometimes my external drive fails to mount. What I do to force it is follow these steps:
Click start and open up a command line window. Either find it in the Accessories folder or type cmd at the search.
In the cmd window, type 'diskpart'. A new command window might pop up. In the new window, or the same one if a new one doesn't pop up, then type 'list volume'. It will list a number of volumes on the system in the form:
Volume ## Ltr Label FS Type Size Status Info.
Find your hard drive in this list and note the volume number. I usually find the hard drive by comparing Sizes, but it should also show your hard drive's name under Label.
Next type 'select volume x' where x is the volume number for your volume. So for instance if your hd happened to be listed as Volume 3, you would type 'select volume 3'.
Now, type 'assign letter=G' or whatever letter you want your volume to be. Once you've done this, your volume should be mounted and you should be able to access your drive normally.
Dec 09, 2010 | Western Digital My Passport Essential SE...
A black rectangle appears constantly with numbers and letters typing in it
hi
you need to go in the menu and remove the cc1
or cc2-3-4 these are screens designed for showing
tv station programming and other infos but they never used it
Sep 28, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
IWhen i turned it on it only types half the letters/numbers etc
It sounds like the Platen roller has popped up out of place on one side. Try pushing down on the black rubber roller (platen roller) on both ends. It is held in place by two black plastic clips that are attached to the roller ends and one of them may be broken. But usually it has just popped up on one side and pushing it down usually solves this problem.
Mar 18, 2010 | Lexmark Wheelwriter 15 Series II...
When I try to type numbers...letters pop up.
press alt or arrow key and select the number key .........repeat the same when u want the number to get displayed in place of letters
Jun 28, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Can't Locate the 3 letter suffix for Magtag model number cwe9000
wether its under the maintop, perhaps on th elecg of the unit itself, or even on top corner on backside of unit, there should be a "identification plate,listing both model and serial number , and yes i just looked up with just teh few numbers you have, and there are a fewe types, its gotto be there somewhere
Jan 21, 2009 | Ovens
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
TYPES WRONG LETTERS
everythin is ok,you by a new wheel with letters and that wheel is for european market ,and y -z ar on the other sides
Feb 04, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Computers & Internet Logo
155 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
