Question about Motorola Mobility H700 Wireless Headset
The microphone I can hear people but no one can hear me it seems that the microphone doesn't work I only had it for a couple of daysHow can i fix the mic.
    Problem Solver:
  • 13 Answers
My only suggestion is go back to place where you bought it and exchange for a new one. Most place have a 30 day return policy. I would try that.
Posted on Jul 30, 2007
SOURCE:
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
May 20, 2012 | Toshiba Satellite M305D Notebook
When using Skype I can hear other person fine but she can barely hear me. I have tried to adjust sound on skype but it doesn't seem to make a difference
I had the same problem and I replaced and/or used "external mic for Notebook " for this purpose and everything is ok now..
pls use new mic and make a test call to SKYPE to hear your mic voice as well..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 20, 2011 | Labtec Verse 504 Consumer Microphone
On skype the other person is not hearing me. i am told it is a problem with my microphone. where is the microphone on the torshiba and how can i fix it
To confirm use an external microphone that is plugged to the mic input of your PC. If the mic works fine then the fault can be the internal mic. You have not mentioned the PC you are using but I suppose it is a Toshiba. If so the mic is located on the base of the PC... look for the tiny grill opening.
Jan 19, 2011 | Toshiba (P000257700) Microphone
Internal Microphone not working
This is not a problem with mic. Settings in System was changed so that mic has been muted. To enable goto contol pannel and Select Sound & Devices and Select Advanced in Device Volume there you will get Master Volume Settings Menu So that uncheck the Mic option and check for Mic Setting in that.
hope this will be helpful.
Thanks & Regards Nanda Kishore.
Apr 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
My microphone doesn't do it right.
Some of the Podcast mics are condenser mics and MUST be used with a preamp or DEVICE that supplies PHANTOM power to the mic.
You computer DOESN"T supply Phantom power.
Read up on Phantom power in Google to understand it.
Apr 03, 2009 | Behringer XM8500 Professional Microphone
Nobody can hear me on skype
It seems like your mic doesn't work. Are you using headphones with microphone?
Go to sound properties and check if microphone is enabled.
Feb 22, 2009 | HP Pavilion dv2000t Notebook
My micriphone attached to headphone seems not to work.
First, make certain that the mic is really broken, by testing it in another application or devise. Sometimes you cannot hear your own voice unless you are in recording mode! If the mic is found to be working, then try to reconfigure the software, or the Yahoo connection. Good Luck!
Dec 06, 2008 | ASUS Computers & Internet
Logitech microphone
Sounds like a physical problem with your input jack. Try plugging it into another microphone port. Most computers have at least two, one in back and one in front.
Sep 14, 2008 | Audio Players & Recorders
Microphone...
You need to clarify whether microphone or its connection bad or system causing the problem. I suggest you to try with external bluetooth or normal headset. If sound microphone works with headset you need to have microphone connection be fixed
Jun 19, 2008 | Nokia E90 Cell Phone (Unlocked) - Black
Motorola Mobility H700 Wireless Headset Logo
221 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
