Question about Pool & Spa
I overfilled the Spa and now the breaker keeps blowing.
There does not seem to be very much water on the inside when I took off the panel? What do I do?
At the moment it sounds like there msut be some water along the lines inside your electrics, the only thing to do at the moment would be to let it dry out and try either in a few hours or tomorrow. it could be causing a cross between the live and earthing conductors.
Posted on Jan 28, 2009
MasterTemp 250 blowing breaker...
Could have a soft breaker.
Have a technician check the amperage draw at breaker pane.
May 21, 2014 | Pentair Mastertemp Heater
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jandy Aquilink control panel keeps tripping circuit breaker
turn off heater if it still happens mark all auxs remove all then try again if it doesnt blow fuse plug 1 in at a time until it does thats whrer your problem is
Aug 16, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My dream maker escape spa 8003 has no power. Almost seems like a fuse, but I can not find a fuse.
check breaker if ok fuse inside panel of controller if bad check recirculation pump or heater element
Oct 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
Pool & Spa Logo
165 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
