Question about HP LaserJet 2420 Printer
HP Laserjet 2420 will not print from tray 2
Hi!
I have a user who is unable to print from tray 2 only tray 1 - used for legal - i saw a response to a similar question - and the recommendation was to try a maintenance kit to replace the feed roller and clean the rollers in the interim - any other suggestions for this issue?
    Genius:
  • 2,120 Answers
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Posted on Jan 29, 2009
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
We have a HP laserjet 2420 and when I try to print anything, it shows "load tray #1, and so I have to press the check mark button twice for it to print from tray #2. I want it to default and to print...
Becouse the tray configured in the printer is tray #1 so it serching the paper on tray 1 first you can set it the default tray by the menu on top of the printer.
Dec 13, 2010 | HP LaserJet 2420 Printer
Legal size no print of hp Laser Jet 2420n printer
Hii It could be wrong on this but there should be a setting on the printer for paper size and type for tray 1. Use it to set tray 1 as legal size and then use your program to send to the printer. Another way would be to have no paper on tray 1 and send the job. The display on the printer should say to load legal on tray 1 and hit the button to continue. When you do the printer will now know it has legal paper in tray 1. The last method is only good for that job and will have to be done the same way for another job. Specifying tray 1 as legal paper will allow you to have legal paper in the tray when the job is sent and not have to press the button.
All the Best.....
Dec 11, 2010 | HP LaserJet 2420 Printer
I want duplex printing for hp 2420
The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | HP LaserJet 2420 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
How do I change tray settings from tray 1 to tray 2?
Browse through the menu's of the printer
Paper Handling Menu, Set
Tray 1: Any size / Any Type.
Tray 2: A4 Size / Plain Type.
This should solve the issue
Regards,
Nikhil
Jul 10, 2009 | HP LaserJet 2420 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
HP LJ2420 won't print legal size
Not enough info.
does it try to,does it ask for the other tray, is it set for legal??????
Nov 07, 2007 | HP LaserJet 2420 Printer
Printing only 1/2 the page
print a demo page(which is in the menu)if it comes out ok,it's either the drivers or possibly the formatter board.if demo is not of,it could be the cartridge.i could help you better if i know which half(right to left or top to bottom)
Sep 19, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
431 people viewed this question
Seeker5211
Seeker5211
