You posted a reply about a freezer that would not defrost back in 2006 on FixYa.You said to jumper the DEF to the LINE on the board in back of the unit.I found the LINE to be hot and jumped it to the DEF and then tested the blue wire inside the freezer and it was hot.This still did not heat the defrost coil.I took out the coil and jimmy rigged power to test the coil, it got red hot.I reinstalled it, tested the blue wire to make sure it was hot but the heater will still not come on.
GE side by side unit model GSS25SGMD
Hope you have time to reply.Thanks, Dave
Dave, you are throwing me a little here. By jumping line to defrost you should have 120 V. at the heater. J-11 to j-9. Are you measuring voltage? Lets ohm out the circuit. Unplug the refer and disconnect the blue connnector from the main board. Measure between the blue wire on the connector and the orange wire on J-7 pin 9. This is right to the right. You should have approx 22 ohms. If you don't have this the problem lies either in the heater, harness,or defrost T-stat. The Tstat sits on the evaporator, opens at 140 degtrees and closes at 110 degrees. So it should read closed. Let me know how you are doing, Catriver
Freezer back wall has a fair ammount of frost and seems to not want to freeze and the fridge seems...
(More)
Freezer back wall has a fair ammount of frost and seems to not want to freeze and the fridge seems to not keep cool and the bottom drawers in the fridge side freeze....also the water line freezes up
Wondering how energy efficient is the Hotpoint CSX20EA 19.7 cu.ft. refrigerator. It is a...
(More)
Wondering how energy efficient is the Hotpoint CSX20EA 19.7 cu.ft. refrigerator. It is a side-by-side refrigerator and it runs fine. It is probably about 20 years old. Never had any problem what-so-ever.
My fridge GE: GSS25SGMCBS. (Smart Water Plus) Water line freezes up. When I clear the line with air,...
(More)
My fridge GE: GSS25SGMCBS. (Smart Water Plus) Water line freezes up. When I clear the line with air, or using a hairdryer it works for a couple of days fine, then freezes up again. Is there a special water dispenser heater kit availabe that GE would supply. Or another easy fix.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
