Question about Maytag MSD2756G Side by Side Refrigerator
Defrost problem folowup
Same problem as another post - freezer freezes great, but the refrigerator side doesn't stay cold. I followed Catriver's instructions (great post BTW, maintenance guy charged me $250 to replace the board), meaning I shorted the L1 to Test on the board and the defrost kicked right in and worked great. So it seems to defrost manually, but I don't think it's working automatically. Isn't it suppose to kick on every 6 hrs or so? Anyway, since the board seems to be fully functional, what's the next step...replacing the defrost thermostat? In case it's helpful, here's the full symptom description: Fridge: 1) Won't get cold (very slow flow of cold air via vent) 2) Ice forms in vent between fridge & freezer Freezer: 1) Ice Block in bottom of freezer & in drain pan under coils 2) Coils Iced over 3) Leaking under freezer door 4) Motor seems to be running almost constantly Past Actions: 1) As mentioned, the circuit board was replaced about a year ago by Maytag...solved problem for awhile 2) Manual defrost will solve problem for a short period of time, but the window seems to get smaller each time (currently about 4 days before fridge gets warm) 3) Last night I cleaned the drain pipe. There was a little gunk, but no major clog. Thanks for the help...GREAT SITE!!!
    President:
  • 878 Answers
Bmurf, This adaptive defrost determined by compressor run time between defrost cycles. It could go up to 96 hours before defrost depending on differnt variables. With the unit running, a good frost on the evaportator and the tstat covered with frost or ice, unplug the refer. Pull the connector off the adaptive defrost board. On the harness, ohm from red to white/black stripe. If your tstat is good, you should read less than one ohm continuity. If it's bad, you probably will read around 240K ohms. This is the resistance of the resistor built into the tstat. On the live checks, plug in the refer. You are going to have 120VAC from Red to white. You also want to see 120V from white to white/black stripe. If you have that, the tstat is closed. If you have less than 120, say 96,100V. on white to red, that means you are dropping power through the 240K resistor built into the tstat. The board senses the tstat is open and no need to defrost. I hope this helps you out cat, thanks for the kind words on your post. Good luck, Catriver
Posted on Jul 27, 2007
SOURCE:
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad. unthawing in freezer...
you have a defrost problem either a bimetal thermostat, defrost timer or a heater. open doors and unplug unit for 2 days to let defrost it will work great for a week or so. not to costly to fix either way
Feb 23, 2009 | Frigidaire FRS26R4A Side by Side...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Re: Refrigator will not stay cold
defrost problems are caused by 3 things
bad: 1) defrost timer/ timer board 2) defrost heater (in freezer) or burnt wire going to the heater 3) bi-metal thermostat (round metal piece attached to the coils with     at least 2 wires going to it)
a good technician can test components without the machine running. all you need is a simple $5 meter any tech that gets angry, show him/her the door!
Jun 15, 2008 | Jenn-Air JCD2389G Side by Side...
MAGTAG PLUS SIDE BY SIDE R/F
If freezer fan is working then it is not automatically defrosting.it's either the defrost thermostat or the heater.
Apr 08, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator
Sani, see if the evaporator fan is running. That would be the fan in the freezer compartment. It moves the cold air to the bottom. If that is ok, then you may have a defrost problem. Is the freezer panel in back all frosted over? If so, it's probabley a defrost issue. Check these things first and post back...Catriver.
Mar 12, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. Catriver..post back.
Dec 01, 2006 | Maytag MSD2732GR Side by Side Refrigerator
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
95 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
