Question about Goodman GMS90703BXA Heater
Heater sounds like it will start then shuts off
When I tun the heater on, there is a delay before it starts firing up the heat & fan part, then it shuts off and restarts over and over again.
  • 2 more comments
  • carno Feb 17, 2009
    My Goodman furnace is sporadic in its cycles. Starts, then runs then the cold air comes and lasts forever sometimes and then other times that cycle is short. It starts when the temp is already at the desired temp. Nothing consistent about the cycles! Sometimes it starts, seems like it's going normally then it'll shut off and 2 seconds later start right back up again. It's really costing me on my utility bill too with all the starting and stopping!
  • mammadukesnj Feb 23, 2009
    Detects need for heat, starts the cycle, pilot lights, gas starts, flame comes on and then it shuts down. I've called Goodman because it is still under warranty, they were so nice. She kept me on the phone and found a serviceman to come out. My suggestion is if your unit is still under warranty you should call Goodman first before doing any maintenance yourself because it can void your warranty. I'm on the phone with them now to schedule a repair. I hope they show up soon because I'm freezing!!
  • Anonymous Feb 28, 2009
    This has happened 2 times in less than a year for me and my landlord sucks. I think these are just cheap pieces of ****. Mad as hell when my family is sitting here freezing.
  • Don Berry May 11, 2010
    Does the flames come on before it shuts off?
There is a little rod that sits in front of one of the flames called a flame sensor/detector, after a few years corrosion can build up on it. There is a little screw you take out then removed the rod, clean it with sandpaper (very fine) and then put it back. If corrosion is built up on this, it cannot detect the flame..this was my problem and it was easily fixable.
Posted on Feb 24, 2009
Sounds like a dirty flame censor to me
  • 1,420 Answers
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Posted on Feb 18, 2009
Display says "CFH" but heatert wont fire up. Just makes a clicking sound
You don't have gas supplied to the heater. It sounds like you have a gas powered unit and the clicking you're hearing is the sparker sparking.
Jun 07, 2015 | Pool & Spa
Furnace kicks on then shuts off
Coleman furnaces us a temperature delay with a temperature on around 130F to 150F and off around 110F.
If the inrush of cold air cools the delay below the off temperature the fan will go off until the heater heats it up to the on temperature.
Jan 06, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Once the heater reaches the set temperature at the thermostat it shuts off.the flame goes out but the pilot light stays on. the heater will not kick back on automaticaly when it gets cold however it will...
you will have to look into why the unit is tripping and needs resetting. Heaters usually have a fan delay, meaning that when the heat is satisfied, the fan continues to run for about an minute. If not, it could cause an overheating issue and trip a safety. Look for that to start with.
Aug 05, 2017 | Williams 3003622 Ceramic Wall Mounted...
Reznor UDAP-100 heater miss fires when it shuts off. It also blows a big flame out when it ignites after the room temperature stablizes.
When a heater kicks on and a boom occurs, it is known as "delayed ignition". Sounds like the alignment of the pilot/ignitor and the main burner(s) is not correct, thus causing the boom at the end of a burning cycle.
Apr 21, 2017 | Heating & Cooling
I shut off the gas to the unit and the power.i
No, that does not seem correct. If all you did was replace the heat exchanger, then tried to start it up, how could everything go wrong. Unless there was another issue with the heater. Not too many people change out the exchanger, unless corrosion has caused a leak there What you CAN try to do is reset the heater. To do this, turn off your heater first-at the toggle switch inside the right hand side door, then turn off the circuit breaker to the heater, wait about 5 to 10 minutes, then reverse the order. Circuit breaker then heater, if you have the digital display, you will see flashing codes, this is the computer resetting, then you should see the normal display. Try starting the heater again. If it still will not fire, let me know if you receive an error code. Also, check to see if the temp the heater is reading is close to that of the actual water temp.
Jun 26, 2009 | Pentair Minimax NT Heater
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater wont start but when i turn off the pump and start back again the pool heater comes on for 2 seconds and shuts off AGAIN
Heater must have water before it will fire up. There is a delay relay that may be dozing off. Not a bad thing but should be chk'd by a pool sevice.
May 26, 2009 | Heating & Cooling
Heater/fan issues
There is a safety switch which will shut the heater element off if the fan doesn't run. If the fan doesn't circulate air, the element would overheat and could possibly start a fire, so the switch will shut the element down. I'm not familiar with this heater, but I would check to make sure the fan is operating and also check for any filters that may be plugged and restricting air flow. If anything interferes with the air passing through the heater, the overheat switch will shut down the element. That's the best I can do from here. Good luck.
Feb 28, 2008 | Vacuums
Dayton gas heater mod 3E404
This is an easily fixed problem. There are two thermistor switches on Dayton furnaces. One controls the fan motor run function and the heater valve on/off function. The other called a blocked vent switch (located in the top front of the heater) stops the gas valve from opening in the event the
vent is plugged. However, if the furnace was totally shut down for the summer and is now being fired up for winter, the block vent switch has to be reset. The switch has a reset button on it, push it and it should solve your problem. Also, check to make sure the fan run thermistor is clean and does not have debris around it as that acts a insulator for heat to keep the fan run function on.
Dec 30, 2007 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
198 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
