Question about Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
I have rewound a bobbin on my sewpro sewing machine. When I loaded the bobbin back in the machine I can't get the machine to pick up the thread to sew again.
    Scholar:
  • 34 Answers
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Posted on Jan 31, 2009
  • talk2ginny
    talk2ginny Feb 04, 2009
    Hi - I'm checking in to see if you've had any luck getting your machine going again. If I can help you further, please comment.
    Cheers!
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
Oct 12, 2014 | Sewing Machines
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
Brother 1100 threading the bobbin
try changing the needle
rethread the machine top and bobbin
make sure to use every thread guide
make sure the top thread has not come off the thread take up
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
Brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Jul 29, 2008 | Brother XL-3500
Sew Pro QuickStitch SP-402 Mechanical Sewing Machine Logo
227 people viewed this question
Top Sew Pro Sewing Machines Experts
Steve
Jamie Sewell
Level 1 Expert
ray gallant
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
