Question about Cameras
My camera wont work on my computer
When i plug my camera into my computer nothing happens. it was working before
  • Anonymous Feb 06, 2009
    camera won't work on pc
  • Cameras Master
  • 4,738 Answers
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following post, as it outlines a much easier, faster, and less error prone way to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on Jan 30, 2009
SOURCE: My camera wont connect to the computer
I have the same proble but it says that the device is unreadable and to get a new device? Anyone have a good link to a new driver? Wonder if that would solve it?
Posted on Jul 20, 2008
  • 97 Answers
SOURCE: When i plug my usb
I have had this problem with Canon cameras, it seems to be a bug in their software. What make and model is your camera?
My solution was to manually open the camera transfer software, and manually select all images for download (rather than using "download all").
Another option is to put the memory card into a card reader and copy the files across as if you were copying them off a USB memory stick. You might have to rotate the pictures manually if you do this and use the camera in portrait format, however. Using a card reader will avoid running your camera batteries down, and will speed up downloads to boot!
Posted on Sep 05, 2008
charcois
  • 763 Answers
SOURCE: Not working
your camera device has a cd driver camed with you camera box. install it on your computer so that your camera will recognize it everytime you pluged it in. hope that helps
thank you for using fixya
CHARCOIS
Posted on Jan 19, 2009
  • 11967 Answers
SOURCE: when i plug my camera into the usb port on
Time to start using a card reader.
Posted on Feb 11, 2010
  • 11967 Answers
SOURCE: How do i upload pictures onto my computer from my camera?
Simple...use a separate card reader.
Posted on Mar 31, 2010
Why wont my kodak easyshare camera c1530 connect to my computer ?
open windows explorer bottom left or on desktop then press computer and see if Kodak is in there if it is then press on it to open Kodak.
Aug 01, 2017 | Kodak Easyshare C182 12MP Digital Camera
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
Nikon Coolpix L22. The computer wire will not work. when i plug it in and put the camera on, it doesnt show anything about the pictures being uploaded. Nothing uploads, nothing happens. The USB cord is...
The camera will need to be plugged in and turned on for you to be able to transfer pictures from it.
Plugging the camera in will not make anything special happen on its own-- if you are using Windows (after the camera is plugged in, turned on, and with your memory card still in the camera), try opening "My Computer" and looking for the camera's icon within that window. The camera (and the photos on the memory card inside) will be shown just as any other CD or jump drive that you would plug into your computer. You can copy photos off of the camera by double clicking the camera's icon, (probably opening the DCIM folder) and dragging and dropping the image files onto some other location on your computer.
Mar 06, 2011 | Cameras
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
When I plug in the M407 camera nothing happens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 15, 2009 | HP Photosmart M407 Digital Camera
Computer wont reconice camera when i plug it in
Well, i'm guessing it's safe to assume that you are plugging it into a USB port on your computer. Most computers will have two or more of these ports on the computer. 1st, try using a different USB port. Make sure that when you connect your camera, that it is turned off. Once connected, turn your camera on. If nothing happens, turn it of but keep the camera connected and reboot your computer. Sometimes it will automatically read what you have stored on your camera. If none of that works for you, i'll look up some places that you could find software compatable with your Canon.
Let me know!
Olivia
Oct 22, 2008 | Cameras
When we plug the camera into the macintosh it wont recognize the camera
Well after a bit of trial and error, I found a somewhat consistent solution.  Here are the steps:
1.  While the camera is off, plug the USB cable into the camera (Don't plug the other end of the USB cable into the computer yet)
2.  Turn the camera on and press the mode button
3.  Navigate to the Camera icon
4.  Plug the USB cable into the computer (the camera icon will change to the USB screen)
5.  You will notice nothing happens!
6.  Unplug the USB cable from the computer
7.  The camera screen switches back to the Camera icon
8.  Plug the USB cable back into the computer and a VTech 773 icon should show up on your desktop.
9.  When your finished copying pictures to your hard drive, drag the VTech 773 icon to the trash.
I don't know why it works but it worked 9 out of 10 times for me.
Let me know if you find a simpler solution.
Aug 18, 2008 | Cameras
Jan 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Won't work on my computer
please make sure the systems usb board is configured correctly before that go to http://driverguide.com and nstall appropriate usb drivers
Apr 23, 2007 | Samsung Digimax U-CA3 Digital Camera
Cameras Logo
123 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
