Question about Frigidaire PLEB30T9DC Electric Double Oven
Odd loud fan type noise
We just had our new double oven installed yesterday. I made dinner and all was fine and normal. Everything was turned off. I did notice it was taking a while to cool down but left the room. About an hour later the oven started making a very loud racket... like a fan but not like it was sounding earlier. It lasted about a minute. We pressed all the buttons we could and nothing help. We opened the doors... the inside was still a little warm... too warm to be confortable to the touch. Then the noise went away. What is this? Should we be concerned?
    Novelist:
  • 159 Answers
What you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Posted on Jul 26, 2007
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Our fan on our oven is super loud. Always has been. We have to keep the door open so that it will cool off asap because it is so loud. What's wrong?
Mar 11, 2009 | KitchenAid Architect Series KEBC278KSS...
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Frigidaire PLEB30T9DC Electric Double Oven Logo
1,427 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Sal De
Marvin
Marvin
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
