Question about Freezers
The red light is on, and stays on?
The red light is on, and stays on. The compressor keeps cutting in and out again.
  • 410 Answers
On the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
Posted on Jan 28, 2009
Should green "compressor on" light always be on?
read the user manual
the light may only come on when the compressor is working
talk with a service agent for the unit and ask them
Dec 29, 2016 | Magic Chef Freezers
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
On a up right freezer the red light comes on and stays on and everytihng defrost what could be wrong
I want you to feel the top of the compressor to see if hot or too hot to keep your hand on the top. Click Here for a photo of the=> FFU2124D System Components item 30 is the 216649315_Relay-and-Overload-Kit item number 55 is the=> 5304464438 Run Capacitor
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
Nov 28, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer ffu14f5hwg red light on
It isn't reaching temperature. The red light comes on at -12c Check the condenser is clean, thermostat set ok and compressor humming nicely
May 22, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
My red light is on and the freezer is not making any sound and is not staying cold
The red light indicates temperature zone crucial. Listen for the sound of the compressor. If it's on and appears to be running, check the condenser to see if it is warm. If so, a faulty compressor may be the problem.
Jan 26, 2011 | Magic Chef Chest Freezer MCCF5WBX
Red light on
you should have have let it sit till the compressor equalize if it was running,you may have ruined the ptc overload relay that protects the compressor,try unplugging it and leave it off for an hour,then retry it,if this doesn't help then replace the ptc overload on the compressor body,they just unplug off the compressor
May 09, 2010 | Whirlpool 7 cu. ft. Chest Freezer EH070FXM
Red light is on on bottom panel and buzzer is going off. Inside temp is 20 degrees and outside temp is 25 deg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 06, 2010 | Freezers
Compressor keeps clicking on then within 2 secs cuts off then on
sounds like you need to replace the relay/overload on the compressor.
Oct 13, 2009 | Frigidaire Freezers
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Jul 17, 2008 | Whirlpool 14.8 cu. ft. Chest Freezer...
Freezers Logo
147 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
