Question about Gateway (4000684) Motherboard
Ram I'd like to know how much RAM my PC can handle? Can you help me find out also I need to know what order to put the Ram chips in, cause there are 2 256mb chips and one 128mb. When I put all three in the computer only registers 512mb. Can you help?
  • swufabuda
    swufabuda May 11, 2010
    Need model name and number of the board..
Part Number: 2511451 Intel (Fedora) motherboard Pentium III - 667-MHz
The motherboard will support a minimum memory size of 16-megabyte (MB) and a maximum of 512-MB. The BIOS automatically detects memory type, size, and speed. The memory type, size, and speed can vary between the sockets. The memory modules do not have to be installed in a certain order or in a specific socket. Bank 0 or the DIMM1 slot is located toward the rear of the motherboard.
Gateway Support Document for your motherboard:
http://support.gateway.com/s/MOTHERBD/INTEL/2511451/2511451nv.shtml
http://support.gateway.com/s/MOTHERBD/INTEL/2511451/251145101.shtml
http://support.gateway.com/s/MOTHERBD/INTEL/2508226/250822604.shtml
Note: The individual part number for this motherboard is 4000684. This number helps technicians locate the motherboard in the CRM. Some invoices list the motherboard separately and not as part of the sub-assembly, which includes the motherboard and processor. You cannot use the individual part number to replace this motherboard. Use the sub-assembly number at the top of this page.
Note: Before adding, removing, or reseating any hardware, verify that the computer is unplugged. Then, either wait 30 seconds or press the power button to discharge the motherboard. The motherboard maintains power even after the computer is turned off.
A bios update is available for your system here:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=2511451
This may, or may not, correct your problem.
Available on the Web at www.gateway.com/support are the following: technical support for Gateway products, live chat with a Gateway Trusted Guide, files for downloading, and e-mail support. Additional technical support can be obtained using Fax on Demand system at (800) 846-4526 and Automated Troubleshooting System at (800) 846-2118.
Posted on Feb 04, 2009
    Problem Solver:
  • 9 Answers
Yedya bhokachya aadi motherboard che manual vaach. tyamadhe sarv lihile aahe ki konta motherboard aahe , kiti RAM support karel.
Aadi tithe gand masti kar mag prashnna vichar...........
Posted on Mar 05, 2009
Tip
10 reasons why PCs crash-You must know tip 2
2 Bad Ram
Ram (random-access memory) problems might bring on the blue screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and will need replacing.
But a fatal error caused by Ram might be caused by a mismatch of chips. For example, mixing 70-nanosecond (70ns) Ram with 60ns Ram will usually force the computer to run all the Ram at the slower speed. This will often crash the machine if the Ram is overworked.
One way around this problem is to enter the BIOS settings and increase the wait state of the Ram. This can make it more stable. Another way to troubleshoot a suspected Ram problem is to rearrange the Ram chips on the motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling Ram try not to touch the gold connections, as they can be easily damaged.
Parity error messages also refer to Ram. Modern Ram chips are either parity (ECC) or non parity (non-ECC). It is best not to mix the two types, as this can be a cause of trouble.
EMM386 error messages refer to memory problems but may not be connected to bad Ram. This may be due to free memory problems often linked to old Dos-based programmes.
on Mar 04, 2010 | Computers & Internet
3 long beeps when memory installed on gateway 700s lx3
The Code Beep Manual tells us that 3 long Beeps shows you that there is a problem with the RAM. Its either it is not installed properly, or it is faulty etc. But in your case, This has to do with the installation of those chips. I would suggest that you install only one chip at a time and check if the system will recognize it and be able to boot. If it does, put it aside, try the next one until you find out which one is causing the problem. If all the RAM chips work, then try two chips at a time, and make sure you keep on trying them only on selected slots, so that it helps you to narrow down your problem because the problem might not reside in the RAM chips but in the slots. Make sure the slots are clean, no dust particles in them, since dust particles can cause static electricity to build up around the system board causing the system to halt.
The other thing you need to consider is how you handle the RAM chips themselves. Make sure you do not touch the part that connects to the slots, because this can also create static electricity that is harmful to your computer. Again check the small lines that go into the slots on thr RAM whether they are all intact (have a goldish shiny look). At times, these lines can burn out causing a discontinuity of the current on the board.
Mar 01, 2012 | Gateway Computers & Internet
Can a compaq presario f700 handle one 2 gb ram chip
Simply put, no. It can handle 2 gigs TOTAL but not a single 2 gig chip in one slot.
Mar 17, 2011 | Compaq Presario 700 470024-192 Notebook
Old Compaq Desktop Pro
The BIOS is unable to access the video system in order to write any error messages to the screen.
This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
If its onboard VGA (Video Card chip built on the motherboad, which I believe it is with a Compaq computer), it is possible the video chip went bad or might be a RAM problem. You can try to open up the case (unplugged of course) and take the RAM out and put it back in, or if you have more than one RAM chip try each one separately.
If you had another computer that uses the same type of RAM, you could try the RAM chips in another computer to make sure it is not the RAM that is causing the beep code.
But 1 long and 2 short beeps usually points to the video card/chip or the motherboard failure.
Mar 29, 2009 | Compaq Computers & Internet
Computer refuses to start: No POST
Is your PC beeper connected and does it gove you any error beeps when you power on (before POST)?
Firstly, ensure you have purchased the correct RAM for your system.
Do you know the model number of your mainboard?
Do you know the model number of you RAM?
Can your MB handle the amount of memory you are installing?
If you give me the model numbers I can check compatablilty for you.
If you KNOW you have purchased compatible RAM, then make sure you have installed in correctly (a very common error, even with myself and very experienced techs). Don't be scared to give them a good push when you install the DIMMs. The locking arms should postion and 'lock in' by themselves.
Are you installing 1 stick or 2 x matched pair?
Are you adding new sticks to existing sticks? If so, remove the old sticks and have only the new sticks in? If this doesn't work then put just your old (working I assume) RAM.... does it work?
Try not to mix RAM types in matched slots.... this can cause conflicts sometimes.
Mar 27, 2009 | Gigabyte GA-K8VM800M Motherboard
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Hi. I have a TravelMate 5620 which has a sticker on it saying 5625WSMi. It had 1Gb memory. I've purchased 2 x 2Gb RAM as found on internet it can handle up to 4Gb. I replaced the 1Gb RAM with one of...
Sometimes, one memory slot can be on the opposite side of the motherboard, under the keyboard. Try removing the keyboard and look under there. If that doesn't help, let me know and I'll look it up in the service manual.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Acer Computers & Internet
I am a novice to computers and would like to upgrade my ram. Could you please help in any way. Thanks Dennis
What type of CPU do you have? Is it a pentium 3 or 4 or dual core?
Are you willing to buy in online or in the store (easier to match what you need)?
If you are going to get it in the store, turn your PC off and locate your RAM. IT will look like this.
Pop a chip out and look at your Mainboard's model number. It is somewhere printed on the mainboard most likely in white. Google it and get the specs to see how much ram it can handle. Take your chip down to Best Buy or your local computer store and get what you need.
There are levers on either side of the ram. flip those out and line up the chips. Press it in until both sides snap in. Put your biggest stick closest to the CPU. If your mainboard is dual channel you will see your 2 ram channels separated. Put identical chips on both sides.
Hope this helps you out.
Jun 12, 2008 | Acer Computers & Internet
Wont recognize additional ram
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Dec 20, 2007 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
210 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
