Question about Sage ACT! 2006 Upgrade Version (License Only) Volume License for PC, Pocket PC, Palm OS
I receive a message cann 't access database( error= 2) see help m
! am using Sage Accpac 500, ERPVersion 5.4, Student Edition..
After setting up my comanpany with the correct procedure for the first time..When entring the session date, neither the two samplle companies or my company will work.
davehope
SOURCE: Logging onto Sage problems
Delete the QUEUE.DTA file from within the ACCDATA folder of your data directory.
Posted on Mar 09, 2009
SOURCE: Sage 50 Accounts 2008
I think I got the solution for you ...
User Name is Already in Use / Cannot Access YYY because XXX is logged in
Typically, when you get this message you will be asked if you want to remove the user from the request list. If you are asked this question, simply answer Yes and you'll be able to continue.
An alternative solution is to go in the data folder for your sage data (the default folder for versions prior to 14 is c:\program files\sage\accounts\accdata for v14, the folder is c:\documents and settings\all users\application data\sage\accounts\2008\company.000\accdata on XP and c:\programdata\sage\accounts\2008\company.000\accdata. In the data folder, you will find a file called QUEUE.DTA - delete the file and you should be able to get back into Line 50. If you have a multi user version of Line 50, you should only delete this file if you are sure that no-one else is using Line 50.
Posted on Apr 16, 2009
SOURCE: error message with sage instant accounts
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
Posted on Apr 17, 2009
SOURCE: Cannot Access database (error=49153)
We are using Oracle, but you may want to try these:
  1. Go to ODBC in Control Panel, and test the Connections
  2. If it still doesn't work, Go to Services in Administrative Tools, and try to restart it (the seervices)...
It worked on us...
Posted on May 19, 2009
SOURCE: Sage Instant Accounts error Message Coming up during Installation
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Posted on Apr 21, 2010
Can not open sage accpac
That error means this entry:
HKEY_LOCAL_MACHINE\SOFTWARE\ACCPAC International, Inc.\ACCPAC\Configuration\SharedData
is not pointing to the folder that contains the *.LIC files. Or, you don't have full permissions to that folder.
Oct 13, 2009 | ACCPAC Fax/Voice/Mobileserve for PC
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
After my computer is up and running, I cannot access my Wordperfect X4, instead I get a Runtime error message! Any suggestions?
try this goto start search type in box wordperfict
you should have arond 5 come up
double click on them to see if it works
if not then wp needs reinstall
Aug 25, 2009 | Corel WordPerfect Office X4 Home & Student...
Error message
Hi beulah_jane,
What version of Simply Accounting are you using? 2007? 2008? 2009? Using Windows XP or Vista? Are the Simply files stored locally on the C drive or on a network? Can you open a sample company or are you getting the same error?
If you're trying to open the file using a shortcut to the data file itself, try using the Simply Accounting Program shortcut and then opening your file. If you're getting an encountered an error message, try searching through our knowledgebase.
In either case, I or another user can help you in our Simply Accounting Community at www.simplyaccounting.com/community
This includes a free Knowledgebase, Discussion Forum and blogs that you'll have access to. You may even find your answer already posted by another user in the forum. We have several knowledgeable users and our business partners going through the forum as well that can help you as well.
I hope this helps.
Andrew C
Simply Accounting by Sage
Online Customer Support Analyst
Mar 19, 2009 | ACCPAC Simply Accounting 2004 PRO...
OmniForm 5.1 , Database error
OMNIFORM 5.1 IS INOPERATIVE, KEEP RECEIVING PRINT SPOOLER AND KERNEL PRINTER ERROR MESSAGES HAVE TRIED TO REPAIR, AND DELETE AND RELOAD. ALL ATTEMPTS HAVE FAILED. THESE PROGRAMS ARE BEING USED ON WINDOWS VISTA
Feb 20, 2009 | ScanSoft Omniform Developer Edition 5.1...
Error message with sage instant accounts
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
It worked on us...
Nov 21, 2008 | Computers & Internet
COMPANY IS MISSING!!!
try checking to see if the company exists in the database setup.
you need to make sure the company database is linked to the system database before it becomes available to use. if it is there, delete the links and recreate them
Feb 22, 2008 | ACCPAC Simply Accounting 2004 PRO...
BCM Problem ... Lost Contacts
The BCM uninstallation doesn't delete your databases. They should still be on your computer here:
C:\Documents and Settings\<username>\Local Settings\Application
With either a *.mdf or *.ldf extension. Those are SQL databases which you can get the data off and into a CSV file which you can import into outlook (of course technical expertise is needed) or you could more easily (once the problem with BCM is resolved), make BCM re-recognize the databases by following these instructions:
1. Go into BCM and create a new database. That database needs to match the
name of the .MDF file. So if the MDF file is named "MyBusiness.MDF", create
a new BCM Database with that name
2. Stop the MSSQL$MICROSOFTSMLBIZ Server by going to Start > Run >
services.msc and selecting the MSSQL$MICROSOFTSMLBIZ service
3. Copy the original .mdf & .ldf files over the blank database. They should
be in the following location
Data\Microsoft\Business Contact Manager
4. Start the Server again (see step 2)
5. Restart BCM and see if you can access your data
which I found here (credit to Larry from the Lockergnome's forums).
If you could write what the error message is I could possibly help you resolve the BCM problem you're having, thereby making it easier for you to view the data on the SQL database files.
Dec 31, 2007 | Microsoft Outlook 2003 for PC
Sage ACT! 2006 Upgrade Version (License Only) Volume License for PC, Pocket PC, Palm OS Logo
512 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
