Question about Dayton Gas Furnace Heater
Pilot wont stay lit installed new gas valve and new thermocouple
I could not get to stay lit
  • rod crear Jan 28, 2009
    it is a stanading pilot also the fan blows across the burners i replaced thr gas vale ane the thermocouple . icouldnt see it clearly but it appeared to be getting a good flame iwll check it again tommorrow thanks
    President:
  • 1,214 Answers
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Posted on Jan 28, 2009
  • Mark Egan Jan 28, 2009
    I bet your going to either find a poor pilot flame, clogged inlet to the gas valve, partially clogged pilot orifice, or poorly positioned and/or adjusted pilot flame.
    Some gas valves have a pilot adjust on them. For a standing pilot valve, the adjustment screw will be hidden under a cap or screw.
2 Suggested Answers
  • 120 Answers
SOURCE: pilot wont stay lit changed to new thermocouple
well if you have 6.2 psig at the valve that is your problem. most valves will only take an inlet pressure of 14" wc or about 1/2 psig. as pilot gas comes out of the valve with no regulation it would be blowing like a son of a gun. so if you have 6 .2" wc,water colum you are in good shape. have you tried to jumper the limit connections? a paper clip would work just fine. but if it does work no fair leaving it in place as a great danger may come your way. tell me what the pilot looks like blue and sharp or yellow and layz. there is a magnet in the valve that the thermocouple screws into but these dont often go bad.
Posted on Feb 11, 2011
Village series QV32B pilot light won't stay lit
Classic symptom of a malfunctioning thermocouple. When you press the knob, you force the gas valve open so gas will flow. The function of the thermocouple is to confirm that the pilot is lit and allow gas to continue to flow when you release the valve. A new thermocouple is not that expensive. Good luck!
Jan 05, 2015 | Heating & Cooling
Tip
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.<br /> 1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)<br /> 2. Make sure that the tip of the thermocouple is in the pilot light flame.<br /> 3. Make sure that the thermocouple is clean.<br /> <br /> if you have done these and it still doesnt stay lit, buy a new thermocouple.
on Mar 14, 2011 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot light wont stay lit it has a blue flame with a yellow tip
This could be due to a bad thermocouple, dirty pilot assemby or a bad gas valve. Clean the pilot assembly and replace thermocouple first since it is inexpensive, and they should be replaced every few years. If this does not help a new gas valve will be needed.
Nov 24, 2012 | Heating & Cooling
Hello, i lite the pillot and and start up fire so its working and some time during the day the pillot goes out?
Mar 21, 2011 | Heating & Cooling
Pilot won't stay lit
If a standing pilot won't stay lit, the usual cause is a bad thermocouple. The thermocouple is a safety device with a probe that is kept heated by the pilot flame and produces an electric signal. Wires from the thermocouple connect to the main gas valve. If the thermocouple fails, the main valve shuts off gas to both the pilot and main burner. When you try to re-light the pilot, it goes out again as soon as you release the pilot button on the valve.
A new thermocouple is only $10 or so, and it's pretty easy to change. There are a number of how-to sites and videos showing how to change the thermocouple in gas furnaces and water heaters, and the process is similar in commercial ovens and fryers. Once you see what the thermocouple looks like and how it's installed in some other appliances, you'll be able to identify it in your fryer and see how to change it. That should get your frying again.
Dec 28, 2010 | Imperial IFS40 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Dayton Gas Furnace Heater Logo
868 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
