Question about Kenwood KDC-715S
Display totally gone.
My display is totally gone as well. I cleaned it as well. Is there a part that should be replaced? The manual does not specify.
  • 2 more comments
  • Nonie Stager Jul 26, 2007
    Thank you for responding--that is more than I got from Kenwood--still waiting for the customer service reps to respond but to no avail. We will pull it apart again and try the ribbon cable. And, yes, it is a flip face and we have always had trouble with alignment--but that is irrelevant with regard to the display disappearing. If required, and the ribbon cable needs replacing--do you know about replacement. What and where to purchase. Your response is very appreciative.
  • shirleyspeak Jul 11, 2008
    I have a Kenwood KDC-715S, it is a flip face that opens and closes. There is no display light to operate the buttons. This happened after the battery was disconected,( Display totally gone ) shirleyspeaks@comcast.net
  • Anonymous Nov 13, 2008
    Everything works except the face doesn't light up anymore.  Cleaned the back but was no help.  I can move the settings (only know as I hear them change)  nothing changes when I wiggle the face plate
  • fideliamarro Feb 20, 2009
    I have no light in the face plate
    Novelist:
    Champion:
  • 218 Answers
I'm not sure if your unit is a flip face, but if it is then the first thing I would suspect would be the ribbon cable that connects the flip face to the main circuit board. Hope this helps.
Posted on Jul 26, 2007
My 2002 Saturn L100 odometer stopped working and isn't clocking miles at all.
Odometer
The odometer is an electronic digital display. Digits displayed are illuminated by the odometer backlight bulb. The odometer backlight bulb brightness is controlled by class 2 messages from the BCM to adjust the display for daylight and instrument panel dimming operation. The trip odometer and total odometer will show in this display area. The push button in the lower right side of the speedometer is used to toggle between the trip and total odometer readings. To reset the trip odometer, push and hold the button down for at least two seconds. The total odometer display has six digits with no decimal display. The trip odometer has four digits including a decimal point and indicates tenths of a mile or kilometer.
The body control module (BCM) stores the vehicle mileage. If the BCM fails, the cluster will display the last valid mileage that was sent before the BCM failed. For replacement of the BCM refer to the BCM section of this service manual. Replacement instrument clusters do not require odometer pre-setting before installation. If the instrument cluster is replaced, the mileage stored in the BCM will be sent to the new cluster via serial data, and shown in the odometer display.
Your best bet , take it to a qualified repair shop.
Jul 25, 2017 | Saturn Cars & Trucks
My display is broken so I cant put oven on any advice
Had a similar problem over a year ago on my Rangemaster, neither of the ovens would come on, only the gas hob worked.
The cost of a new display unit was around £100 plus so decided to check out the unit by removing it (it was quite easy to do; but remember to isloate the cooker from the mains before you start dismantling).
On my display there were six wires plugged into it. I marked each one and the display before removing them so that they all went back to the correct location (i am not an electrician and am therefore an electrical numpty).
Firstly I degreased each male and female connector using an electrical spray degreaser/cleaner and then cleaned them using very fine emery paper and a special pen with glassfibre bristles until they gleamed and then gave them a final spray to remove any debrie left by the cleaning process.
Before i put everything back i also cleaned all the connectors to the switches etc which were accessable in a similar manner; about another eight/ten in total.
Following reassembly and switching the power back everything started working again. All this work took about an hour and my cooker has been working fine for the last 12 months.
Nov 16, 2014 | Ovens
I have a pioneer KEH-P4100RDS head unit which the display has gone dim on ( seemed to half go out then a day or so later go fully out ), everything else works so was wondering if it is possible to replace...
Another issue with detachable face units is the spring on the latch gets weak over time and the contacts will not be 100% reliable. Try cleaning the contacts between the unit and the faceplate and also make sure there is not debris in any of the latching mechanisms that could be causing the face to not sit totally flush on the receiver. By the way, cassette tapes...really?
May 31, 2010 | Pioneer DEH-P645 CD Changer
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Jul 09, 2009 | Samsung SGH-D500 Cellular Phone
Roland vs-1880 workstation graphic display gone blank
there is a bulb in the display to backlight it..it probably burned out.
Jul 03, 2009 | Electronics - Others
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cant see any dispaly
it appears that your display has gone bad or there is a display connector problem. If you are tech savvy then open the phone carefully and on proper examination u will find that there is a connector for the display carefully take it off and replace it. Check if it works if not replace the display
Nov 13, 2007 | Nokia 6630 Cellular Phone
Manual default for dopod 577w
Sorry for you. I guess your display driver is gone. That's why you only see blank white screen.
Sep 05, 2007 | Dopod 577W Smartphone
Kenwood KDC-715S Logo
137 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
