Question about GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH
GE chest freeze won't get cold
I can hear the compressor turn on it will run for approx. 20 seconds and kick off. A few minutes will pass and it will kick on again and kick off after 20 seconds. This freezer was working we moved it and now its doing this.
  • 410 Answers
The noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Posted on Jan 28, 2009
    Genius:
  • 2,920 Answers
Sounds like its out of freon
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer not getting cold
Alissa,
Try placing two or three jugs of water in the freezer and wait 36 hrs. before opening.. If the water is frozen solid you have no problems.. if its not frozen, the call a service tech..
Jun 22, 2017 | GE 16.7 cu. ft. / 473 liter Upright...
Can a fridigidare fc5n chest freezer be recharged
If the unit's Compressor is not starting you need to bypass everything and test the compressor directly to see if it will run. best done buy a qualified Appliance tech unless your from and electrical background? also when the motor/compressor is tested they can see if the freezer starts to freeze down. Because of the cost of changing the Compressor and the fact that a lot of the gas leaks in these units can not be repaired due to the leak being inside the freezer walls a new Freezer is still the best option. Also when a Fridge or freezer is left to sit for 5 years the Compressor is likely to have seized and rust may ave formed inside units copper pipes. Cheers
I'd recommend a new Fisher and Paykel Chest freezer with a extended warranty. cheers
Mar 27, 2009 | Freezers
GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH Logo
1,073 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
