Question about Presto HeatDish Compact Heater
How the heck do you clean this dish heater?
This dish is on it's 3rd winter and I just can't bare to run the thing without cleaning the dust it accumulates. It's all on the inside back panal. My husband says...after close inspection...that he guarantees taking the rear screws out won't help. Although we have BOTH have studied the front of it and cannot find a way to remove it short of bending the thing...I compromised and said I would look online. He's out snow blowin'...we just moved to Upstate New York from Arizona. I'd love to get him warm when he comes inside...We usually use propane but after finding the price of propane went up A LOT a few days ago, we've been trying the heat dish again...Thanks...
  • 1 more comment
  • Anonymous Feb 02, 2009
    I have 3 of these heat dishes and I can't figure out how to get the front off to clean them either. Anyone know how to get the front off without hurting the heater.
  • Anonymous Feb 04, 2009
    Just use and air compressor and blow the dust out with compressed air.
  • jbarnable Mar 23, 2009
    Compressed air only takes care of dust; what about other dirt that has managed to get stuck inside the dish?
Just stick a wet rag in the machine and swirl around with a stir stick, done deal
Posted on Mar 15, 2009
Ran into the exact same problem and like you, saw the front isn't removeable. We had a duster that worked that I will try to describe. The duster has those long, fluffy strands that are micro-fiber or something that dust is supposed to cling to, and although it did not look as though it would fit through the grid, it did. Ours has lime green strands and a fairly long black plastic handle for reaching high places. I wish I knew the brand name or even what the thing is called--sorry!
Posted on Mar 04, 2009
Use an aerator spray as used on computer kyboards. Works fine.
Posted on Mar 03, 2009
How do i Clean presto heat dish
It all depends on the how much dust has accumulated on inside of the dish.
Try to use the Swiffer first before mechanically altering any part. Slide the duster in through the grate, and move it around. Pull it out and repeat on the other area. You'll just have to do this around 3 times.
If heavy clean is necessary, then you might have to resort to bending the lip of the dish to separate the grate off from the dish.
IMPORTANT: make sure the unit is unplugged and cool down before attempting any of these cleaning methods.
May 22, 2014 | Presto HeatDish Compact Heater
I love this heater but now after a few seconds of running it shuts itself down. Im wondering if there is too much dust or something that is causing it to overload the heat sensor? Its level on the...
I would definitly try to give your heater a through cleaning before before giving up on it. Remove screws that hold back cover on and remove cover. There shoulb be a fiter directly behind it,remove it and give it a through cleaning. I don't know on the new ones if the filter is made of foam material,the older ones like mine are.It is safe to wash them in warm water and a little dish soap. Rinse fully and pat dry. Clean any lint,hair,dust or any other foreign material from fan motor. Blow it out with compressed air if you can. You can use a tooth brush to clean around motor shaft and air ports on motor. You can use a couple of drops of fine grade machine oil on motor shaft,such as 3 in 1 oil or WD-40. Wipe off excess. Lightly brush heating elements and reassemble. I hope this works for you. Thanks We had our first pelonis disc heater for twenty years.
Nov 18, 2010 | Pelonis HC-461 Ceramic Heater
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
How do we clean the inside of the dish?
This is from Presto
- is tipped
Jan 08, 2010 | Presto HeatDish Compact Heater
How to clean dish? Safety grate covering face of dish does not appear to have a way to remove it so backed on dist can be removed and heat dish can be returned to near new condition. Thanks, Mike
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 21, 2009 | Presto HeatDish Compact Heater
Will not stay on
Hi There
OK here's what you do.You need to take off cover there's one screw on each side take those out and the front will raise up. Take a can of air and blow everything clean.around the lines back off it, pilot lite where u see dust. Reason i say this because i got the same heater as yours and i clean it every year before winter to make sure i use it. My heater did the same thing and i clean it and it work fine then i done the same thing every year. I don't have the problem no more. Hope this helps you in the right direction. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Dyna-Glo D-E39 (LP) Wall Mounted Panel...
Please give me the number on how to purchase dust remover that came in presto heat dish box. Thank you!
- is tipped
Oct 25, 2009 | Presto HeatDish Compact Heater
2004 kia sorento no heat
I had a similar problem with AC & Heater fan,it works on and off, and sometimes if the road was rough it runs, So I had to remove the fan clean it with a blower from dust and debris, then I installed it back and it is running ever since for more than a year without having to replace it.
Dec 08, 2008 | 2004 Kia Sorento
Dish washer frigerdaire, some dishes do not come clean
ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Cleaning the dish on my Presto space heater.
I pried the upper rim with needle nosed pliers --,just enough to get the grid off. After cleaning with Mister Bubbles, I popped the grid back in and bent the rim back down. I then took a hammer and
smoothed the rough edges. Looks almost like new!!
Feb 26, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
276 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
