Question about GE Hotpoint Top-Freezer Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
The bottom of fridge and freezer are cold - so cold the items in bottom drawer on fridge are frozen too. Top portion of fridge and freezer not cold enough. I have vacuumed the back of the coils to remove dust but not any better. Small amount of ice on the wall of freezer towards top.
Please help!
  • aprutz Nov 20, 2011
    I have a side by side GE refrigator. The evaporater fan stoped working. Befor this it would trip the breaker every few weeks. where is my problem at? thanks
    With the evaporater fan not working the top of the freezer and refrigator are warm and the bottom of both will freze everything
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Dec 26, 2010 | Refrigerators
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Bottom Freezer is cold top Refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator cooling system problem
My guess is that you need more refrigerant gas. It may also have a problem with the auto defrost system for the freezer. You have a block of ice in the evaporator instead of clear fins for the air to pass through. Make sure the door is correctly closed and that the magnetic door gaskets are in good condition. Once those are fixed you can turn the thermostat to make the fridge a bit warmer. Another possibility is that the circulation fan in the fridge has failed. Cold air falls to the bottom which is why your veg is freezing. You can't work on refrigeration gas yourself anyway, so call an engineer. Correct diagnosis of the fault will be cheaper.
Google
'<your city> GE refrigeration service'.
Dec 06, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
FRIDGE FREEZER BUT FRIDGE STOPPED WORKING FREEZER WORKING OK
look on the back wall of the freezer is there snow? if so you have a defrost component out (timer, limit, or heater) the fresh food compartment gets cool air from the freezer so check for blocked air pathways the build up of frost in the freezer stops air flow so you will be cold on freezer side and warm on ref side
Apr 24, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrigerators Logo
721 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
