Question about Delta & Single Handle Shower Faucet
Can't remove the housing of a delta 1348 shower faucet for repair
The faudet leaks, the housing - a blue plastic part inside the faucet - seems to be nailed insde and can't remove it without breaking something.
Thanks
    Problem Solver:
  • 7 Answers
Their is a silver ring around the blue plastic cartridge.You need to unscrew the silver piece counterclockwise.But make sure the water is shutoff first.
Posted on Feb 02, 2009
How do you adjust pressure on delta 1348 one handle shower? Thanks for your help, Al
There is not water pressure adjustment on this faucet if the pressure from the shower head has gone done from what it was after the new install remove the shower head and clean it and make sure any inline filter screens are without debris.
Feb 09, 2011 | Delta & Single Handle Shower Faucet
I have a very old single valve peerless tub/shower faucet that leaks out the spout when turned off. I removed the knob and there seems to be a plastic part that surrounds the stem and may also serve as a...
im sorry i dont know how to explain step by step what you have to do but i know what you are talking about and its called a diverter. they get stripped out and thats why the spout leaks. they are not difficult to replace depending on the model but some of them have to be sweat apart with a b-tank.
Feb 05, 2011 | Delta Faucet Peerless& Shower Faucet...
When delta shower faucet turned on the water comes out of tub spout as well as the shower head, rough in valve is installed correctly with the word up, up
Sounds like the delta people forgot to install the diverter piece inside of valve body,small white plastic piece screwed into valve. If you take out valve you should see it up inside body
Jan 28, 2011 | Delta & Single Handle Shower Faucet
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Faucet on my shower constantly leaks
    if this is a delta faucet there are two gaskets and springs that need replacing. very easy and these are available at any hardware store. all delta take the same set. turn water off, remove handle with allen wrench (screw is under the red and blue swirl), twist off end of housing, remove ball or cartridge, replace seals.
    Dec 05, 2010 | Home
    Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
    Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
    Oct 06, 2010 | Delta & Single Handle Shower Faucet
    How do yor remove a shower control to fix leaking water does not turn off complete I took out screws but can,t seem to pull off the handle
    handle has a plastic lid that pops/pries off and has a screw under it. Make sure to turn off the water supply to the bathroom or house before you pull out the cartridge.
    Sep 27, 2010 | Delta & Single Handle Shower Faucet
    Bathtub faucet leaking cant find water shutoff
    sometimes you have to shut the whole house off to fix a faucet,..sounds like your in this situation,....no biggie, just shut off whole house and do your repair.
    Jan 30, 2010 | Delta & Single Handle Shower Faucet
    Slow leak old delta
    The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
    Sep 14, 2009 | Delta & Single Handle Shower Faucet
    Delta & Single Handle Shower Faucet  Logo
    527 people viewed this question
    Top Delta Home Experts
    Mike
    john h
    Tim Whalen
    Are you a Delta Home Expert? Answer questions, earn points and help others
