Question about Motorola Mobility i870 Cellular Phone
Overextented my flip on 870
Now when i open flip screen shuts off after the flip is opened so far. what can i do to fix ??
  • herediawil Mar 15, 2009
    The problen is,when I put on the cell ,the ligh in the LCD is off.
    Problem Solver:
  • 18 Answers
You will need a flip replacement on your phone. This will more than likely fix your issue. Just visit your local Sprint repair center to check for that part in stock. You should have a working phone in no time assuming they have the part. Charges may apply depending whether or not you the service plan.
Posted on Jan 28, 2009
My acer aspire5100-5022 blank screen.hooked up to a external monitor no problem. Is there a fix?
The reason the screen of your laptop is not functioning fine could most likely be of two sources.
1. The screen might be faulty,
2. The flip might be faulty.
To fix the problem if the screen is faulty, all you have to do is to replace the screen.
How to fix the screen?
  1. get the appropriate screwdriver,
  2. get an alternative screen or a new screen,
  3. open the laptop from the bottom,
  4. carefully force it open from the sidelines,
  5. try to disconnect the screen from the board,
  6. then you can REPLACE it with the new screen,
  7. couple it back together and it will start working fine.
fixing the flip?
  2. Open the laptop,
  3. check the connection from the link that assists in flipping the laptop,
  4. Check the cables link on the board,
  5. check for any faults and correct it,
  6. couple it back together,
  7. charge it for a while turn it on.
take care
Jun 18, 2010 | Acer Aspire 5100 Notebook
Camera switches itself off unless the viewing screen is closed.the camera will still take shots using the viewing lense but will shut off immediately if the screen is opened.
This behavior comes when the camera is confused about whether the flip-screen is snapped into the camera screen out or screen in (for protection). The screen is supposed to turn off automatically when you snap it into the camera-back screen down. But if you flip and twist it in a certain way, the camera gets confused. I'll bet that if you keep your screen out, on the side of the camera, you can take pictures just as well as ever. To fix the problem, flip the screen out with the camera on, then rotate it all the different ways you can which allow you to close it with the face out. One of the orientations will leave the screen on, I believe. At least this procedure is the one I followed on my A610 to fix the same problem.
Mar 30, 2010 | Canon PowerShot A610 Digital Camera
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
Screen is dark when I flip it open
Change LCD flex it will fix the problem link
Oct 15, 2009 | LG Shine KE970 Cellular Phone
V3 wont recognise when flipped open.
It means ur handsets display strip occured problem
there is only one solution that replace the STRIP
May 19, 2009 | Motorola Mobility RAZR V3
Motorola razr V3m cellphone has a white screen
Unfortunately you are going to have to change your screen. The following link is a step by step with pictures and explanation on how to do it.
Please remember to rate me.
Feb 02, 2009 | Polaroid I533P Digital Camera
I overextented my flip on the 870 pls help now when it opens the screen goes blank
This issue can be resolved by getting the flip replaced on the phone. You can check the nearest Sprint repair center to see if they have that part in stock. If they do, you should be able to get your phone fixed right on the spot. Charges may apply if you do not have the service and repair plan.
Jan 28, 2009 | Motorola Mobility i870 Cellular Phone
My Razr Isn't Aware that it is Closed
most flip phones, or flip anythings use magnets and sensors to detect if they're closed or not. Let's do a little experiment. Take a magnet. Now, run that magnet just above and right of the opened RAZR keypad. If your phone acts like it's been closed, then there's nothing wrong with the sensor. That's a GOOD thing. All that needs replacing is the magnet in the top part of the phone. It's located the bottom right of an open phone below the screen, right beside the camera on the inside. Replacing it is as simple as going to http://www.cnn.cn and ordering a new one. (you'll need a T7 driver to open the top part of the housing) If it doesn't shut off then the sensor itself is shot. As far as I know, there's no where on the net to get a replacement component for it.
Dec 14, 2006 | Motorola Mobility RAZR V3
Motorized Screen gets stuck sometimes - Any fix for it?
Mine does this too, it need a new gear for the actual flip out, if you send it to Alpine they will fix it for around 25 to 30$$.
Sep 27, 2006 | Alpine IVA C801 Car Video Player
Motorola Mobility i870 Cellular Phone Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
