Question about Brother MFC 8500 All-In-One Laser Printer
Need instructions sheet
I am having trouble finding the directions on how to use the mfc 8500 fax. My friend gave it to me when he got a new one and lost the directions.
Thanks!
Lisa
We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My MFC 8500 brother fax machine reports poor line condition when i try to use it with Magic Jack. Is there a solution?
You might try a better/faster internet connection or a faster computer to run it off of. VOIP phones have troubles handling faxes for this very reason.
Mar 09, 2010 | Brother MFC 8500 All-In-One Laser Printer
Have the brother mfc-5890cn having fax issues
Can you hear the receiving fax pick up the line? If so, you may need to slow the speed of your fax modem to allow for poor line conditions. You can find the instructions on page 12 of the Users Guide. If you don't have one, you can download a PDF file of the guide on the Brother web site.
Oct 09, 2009 | Brother MFC-5890CN All-In-One InkJet...
How to print fax confirmation sheet - MFC-7420
first print out the help sheet, might be in reports then u have all the information at hand
Nov 21, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8500 Fax Error 77
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Jun 13, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
FAX CAN BE SENT BUT NOT RECIEVED
check this out. Reinstall the new drivers and utility.
brother diver
please rate me
Apr 04, 2008 | Brother MFC 8500 All-In-One Laser Printer
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
