Question about Sharp AL 1631 Copier
No copy we can print out but not copy
    President:
  • Sharp Master
  • 990 Answers
Hello sir; do you forgot to install the drum unit, or check the charge corona located at side door.
Posted on Jan 28, 2009
Canon IR400 print copy to black print
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
How do I make copies
What do you mean by copies? Like printing 1 page in more than 1 copy?
In the Print dialog box (when you click the File => Print command), You can increase the number of copies to be printed in just one printing.
If your printer is multi-function (one printer that can scan, copy, and print), just place the document to be copied (photocopy) in the scanner tray, cover it and then PRESS the OK. In some models, it is MONO or COLOR under START button group.
Feb 06, 2010 | Office Equipment & Supplies
I have a new photosmart C4680 printer and I can only print one copy at a time from my computer. I want to print two or more copies at a time. What do I do to make this happen ?
Usually the number of copies of a certain print job is handled by the software.
Example: You have written a one page letter using WordPad. You would like the C4680 to print 2 copies of this letter:
1) On the menu, click "File"
2) Choose "Print..."
3) On the page that follows, change the number of copies to 2. There are other options you may choose at this time, if desired.
4) Click Print
The unit should start printing 2 copies of your letter.
Jan 05, 2010 | Office Equipment & Supplies
Need to print more than one copy
If your printing from Windows, when the print dialogue box comes up look for the option number of copies. Change that to the specified number you want to print out and then hit print.
Jun 13, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
Help printing out more then one copy
In the print dialog generally accessed through File -> Print... or Ctrl+P), set 'Number of copies:' to the number of copies you require.
Mar 30, 2009 | Lexmark X4270 All-In-One Printer
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
Getting more copies at once
In almost any windows application there is a command in the FILE dropdown menu that is labeled "Print..." It's usually right above "Print Preview". To print multiple copies click "File" then click "Print..." and you will get the following Windowa63a80c.jpg Just select the number of copies you want by clicking the up/down arrows where it says "Number of copies"
Dec 19, 2008 | Office Equipment & Supplies
Printing 2 copies
Please print a configuration page and let me know if that prints 2 copies as well, If yes,
within the menu, go to configure device > printing > copies, change the copies to 1
Let me know the next update.
Oct 29, 2008 | HP LaserJet 4250n Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Sharp AL 1631 Copier Logo
18 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
