Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Scan question How do I add a computer to be scanned to?
How do i access the web browser administration panel for the copier or the scanner. I dont know the username and password
Posted on Mar 16, 2011
    Genius:
  • 2,120 Answers
Through the web browser. Enter the ip address of the scanner section into Internet Explorer.
Posted on Jan 28, 2009
How do I reset my kenwood TK-3212L
ADD TO SCAN/ DELETE FROM SCAN
Press the key programmed as Scan Delete/Add to add or
remove each channel to or from the scan sequence.
• The channel add indicator ( ) will appear on the
display when the selected channel is added to the scan
sequence.
Press and hold the key programmed as Scan Delete/Add to
add or remove each zone to or from the scan sequence.
• The zone add indicator ( ) will appear on the display
Oct 14, 2014 | Radio Communications
How do I add my computer to the HP Officejet 6500 wireless so I can scan. I am trying to scan from the glass, when I hit scan it only has my wife's computer listed
on the computer that you want to scan from click start > control panel > printers then click add and choose network printer. it will then scan for the printer and add it . you will then be able to scan files to it, once it has installed the drivers and configured your pc.
Please vote if you found this info useful
Mar 13, 2011 | HP Officejet 6500 Wireless All-in-One...
I can't get my hp 6110 to scan to my computer
GO to add scanner utility and try to add the scanner if it ask for the driver insert the disk.
May 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
"no scan options"
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP Photosmart C6280 Printer
I can not scan. It always says cannot scan. Try
is it making copies properly????if yes then clean the scanner bed...try again..else go to control pannel >>add or remove program>> delete solution center>>smart web printing>>photosmart essential...restart the computer...then put the cd in..click on add more softwre>>solution center>>photosmart essential..it wil work..if not then open solution center>>settings>>scan option...transfer all the option to right side...update the list it will work
Mar 24, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Hp6280c does not list computer in scan options
Click Here and follow the instructions to add your computer to the scan destination options.
Apr 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Dec 21, 2008 | HP Photosmart C5280 Printer
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
Scanning
My Photosmart 2575 v has worked fine as well for over a year and now it won't scan. I get the same message: "Refer to device documentation to troubleshoot". I ran all updates and they said I have them all and everything is working perfectly. It's not though. I still can't scan. I tried their work-around by opening paint and then acquring image from the scanner but that does not work either.
Apr 30, 2008 | HP Photosmart 2575 All-In-One InkJet...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
170 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
