Question about Kyocera FS-3900DN Laser Printer
Factory Defaults for Kyocera FS-1300D
How do I reset the network card on the above printer. Somebody set the IP to one that is already in use by a Dell laser printer.
Thank you
  • 28378 Jan 28, 2009
    Is not a Dell Printer and I already figured out that the network card is bad. I downloaded the Quick Setup utility to configure NICs and it did not see it even when I typed the MAC address
    Genius:
  • 2,120 Answers
In printer properties.
Posted on Jan 28, 2009
    Scholar:
  • 107 Answers
Turn off the Dell printer (assuming you want to keep that IP address as is). From the computer/server the printers are networked to, go to Printers and Faxes and locate the printer. Right-click on the printer > Properties > and there should be a tab where you can change the IP address within...sorry I can't recall the exact steps from here as I don't have access to do so from my machine. Once you change the IP, reboot printer and your conflict should be resolved.
If all else failes, you'll need to consult the NIC card manual for further diorection.
Want to reset assigned Ip address on a dell 1720dn printer
When the Ready/Data light ready_light_icon_0.jpg is solid, press the Continue button continue_button_0.jpg to print a menu settings page and a network setup page.
Select TCP/IP heading on the network setup page.
There you can change your IP address.
Aug 10, 2011 | Dell 1720dn Laser Printer
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
How to reset to factory default Dell 1720 network printer
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
Jul 28, 2009 | Dell 1710n Laser Printer
Set up Dell 3010cn as network printer
Have you set it up on the network already or is this the first time? If you have set it up, you can access the network interface by inputting the printers IP address in your internet browser address bar.
If you are unsure of the current IP (assuming it's connected) try print a settings page. It should be on there.
Feb 18, 2009 | Dell 3010cn Laser Printer
Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Dec 28, 2008 | Dell 1720dn Laser Printer
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
DP-190 Network Printer
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Feb 28, 2008 | Panasonic DP190 All-In-One Laser Printer
Network Printing
what you need to do is use a router and set the gateway to the machine and then you can comunicate with using the proper drivers
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/gdi/eng.html
Kyocera FS-3900DN Laser Printer Logo
4,784 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
