When my washer reached the spin cycle it's making a load buzzing noise and not spinning?
  • 15,935 Answers
It appears your timer or pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front loading washer won't spin.
I removed the lower front panel. There's a manual inside and I used the instructions to retrieve the error code. The code indicated a door latch problem. I couldn't do much about that, so I ignored it & kept looking. I completely removed the rubber drain fitting. Inside I found 2 quarters and an underwire from a bra. It was really hard to put back together again - I used a small pair of vise grips to keep each clamp open while slipping the rubber over the plastic fittings. To my amazement, this fixed my problem! All I need to do now is cancel the service appointment.
Sep 01, 2009 | Kenmore Washing Machines
Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
May 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
It makes buzzing noise and doesnt work
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Dec 11, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
