Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Fan motor will not spin but when I take off the part where you adjust the air pressure the fan will spin freely
  • 232 Answers
Once the plastic end cover is removed, remove the lint filter to expose the air pump rotor. You will probably find that it is shattered & is binding. Measure the thickness of the rotor & replace, then set the pump pressure. These rotors are real scarce now, so don't wait too long.
Posted on Feb 06, 2009
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Heater will not start. When plugged in, it just produces a buzzing sound. Kerosene is full, and fuses are good. What can I do?
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When I plug the unit in, the fan turns very slow, and I smell fumes, but the unit does'nt turn on
I am not able to give you a solution, but will put forth some possibilities for you to check.
  1. Spin the fan manually. No power, please. If the fan spins freely, and no grinding is heard or felt, then the starter capacitor or starter relay (whichever equipped) is defective. Internal capacitors are not serviceable. Replace the motor.
  2. If the fan does NOT spin freely and/or binds, either the rotor (air pump) is broken or a motor bearing is bad. The rotor is replaceable, the motor bearing is not serviceable.
If you decide to repair the heater as described then the air pump pressure must be reset, in either case, in order for the heater to burn properly. It is a simple process. Follow this link for instructions
http://www.reddyparts.com/pressure.htm
Nov 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My maytag air conditioner turns on you hear the motor but no cold air and the fan does not blow
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 25, 2009 | Maytag M6X06F2A Air Conditioner
The rooftop a/c comes on, but the fan does not blow air. On a 2004 starcraft popup trailer
Aug 22, 2009 | Dometic Rooftop RV Air Conditioner
Motor and fan fails to come on
Aug 15, 2009 | Ruud Matching Split Air Conditioner
Duo Therm kicking on the compressor, getting cold, but no fan!
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Just replace compressor keep tripping circuit breaker
The fan motor could have been your problem all the time, because if the fan doesn't come on or runs slow, it causes high head pressure,
which causes high amps, which could trip your breakers.
Aug 02, 2009 | Heating & Cooling
Fan won't turn on. When I turned it on for the first time this summer, it won't blow cold air. I tried the different settings. The air compressor comes on, but the fan doesn't. Nothing happens with the fan...
Jul 26, 2009 | Maytag M6Y12F2A Air Conditioner
My condensor motor does not work
Shut the power off to the unit,then spin the fan blade to see if it spins freely, if it doesn't spin freely the bearings are bad, if it does spin freely then check the capacitor, if capacitor if ok, turn power on to see if the motor is getting the proper voltage, if it is the motor's bad and needs replaced.
Apr 25, 2009 | Weather King 10AJA4201AH Air Conditioner
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
52 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
