Cant view screenshot photos(only grey saying no thumbnail) cant save camera photos. my phone storage is not full.my sd card is not full
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SOURCE: SD card Protected
It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
After having the same trouble, I installed a 1 gb card and it worked just fine. It appears the Kodak C330 won't recognize a 2 gb car.
SOURCE: Card error on Agfa digital camera
Get a card reader (they don't cost much) and download your pics to your computer. Then, put the card back in the camera, go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and optimize your card. My advice, don't leave your pictures on the card for very long...get in the habit of downloading on a regular basis and format the card regularly.
SOURCE: new sd card says full
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Testimonial: "you are right, thank you so much!"
