Question about Brother IntelliFAX 2800 Laser Fax
My Brother Intellifax 2800will not print a fax. It says "Check Papoer-Reload paper by using llever - then press Fax Start." I do this then it says "Printing" and kicks on but then starts all over with "Check Paper......." help! Ed
  • ebushman Jan 30, 2009
    No smudge, no piece of paper. The feed rollers are not even turning to pick up the paper. I can hear the typical little clicks and sounds like it is firing up to run--but then nothing!
    Help!
  • Anonymous Mar 15, 2014
    Gets print unable message after warm up. sometimes goes into ready mode then after about 15 seconds display reads print unable ED
    Scholar:
  • 75 Answers
Is there a smug mark on the paper in the cassette. If there is then the feed roller needs to be cleaned ( alcohol ). If paper is out of the cassette & in to the delivery asm. then you have a small pice of paper stuck somewhere in the paper path ( hard to see if this is the prob. ) will need to dismatill the paper pathe asm. hope things work out.
C.W.H.
Posted on Jan 29, 2009
  • typboy Jan 31, 2009
    There is a separation pad under the feed roller that can git out of position. hard to see but look close if an off white piece of rubber is out of place.
How do you get a page count for a brother intlei fax 1270e
On most IntelliFax machines, you can see the page count by printing out a user settings list and looking in the lower right corner of the list. Some list the page count, others don't.
On the IntelliFax 1270, follow these steps to print the user settings list.
- Press Function.
- Press 3.
- Press 6.
- Press Start.
Aug 05, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
How do I set the machine to receive automatic instead of manually
go to initial set up , receive mode, change it to fax only
May 24, 2010 | Brother IntelliFax-2820 Laser Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Will not allow printing from the bottom internal tray; it does pr
SOUNDS LIKE YOU MAY HAVE A SENSOR THAT NEEDS TO BE RESEATED LIFT THE FRONT COVER AND LOOK INSIDE WHERE THE SENSOR ARE GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother® IntelliFAX® 5750e Laser Plain-Paper Fax
THERE ARE TWO REPORTS:-
1-transmission verification report.
2-fax activity report.
for(1)press menu-2-4-1
for(2)press menu-2-4-2.
Mar 20, 2008 | Brother IntelliFAX 5750e Laser Fax
Fax in memory
Either load paper or ink cartridge. If it is paper I think you will need to either press the start button or the stop button then it should start printing automatically.
If it is the ink cartridge after you have installed a new one then it should start printing.
Hope this is of some help to you
Thanks J
Nov 06, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 2800 Laser Fax Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
