Question about Home
Whirlpool washer uneven basket, noisy when washing
They told us to balance the legs on the botton, whirlpool - difficult to turn the knob.
how else may you balance the bucket
    Scholar:
  • 35 Answers
This Solution is Considering that there is nothing wrong with the Washing Machine itself.......If the Adjustment Knobs are Rusty and will not move, you can try and spray or apply WD 40 or Liquid Wrench to the Nuts and Bolts. Something to loosen the Bolts. Apply it a few times a day and let it sit for a few hours or longer. Then you can try to move the Adjustment bolts again. Okay you tried that and it didn't work. The only Option left is to SHIM underneath the Adjustment Bolts. You Will Need a Level and another person to help with LIfting the machine. You can use Wooden Shims, or even better yet you can use Rubber Chair Bottom Caps or Rubber pieces that are used under furniture legs. You can find these at most Hardware stores. Just Start at the corner that needs to be raised and start SHIMMING from there!! If you still have problems and your washer is working properly, then you may have to unhook the washer, lay it on its side and remove and install new Adjustment Bolts. Hope this assists you in your quest to balance your washer.....Joe
Posted on Jan 29, 2009
Basket spins terribly uneven.
If you find no problems with the suspension rods and springs, you can remove that spin basket and check for an item that could be stuck between the spin basket and the plastic outer tub. Also, check the "balance ring" on the top of the basket. The should be fluid in it. You can check this my shaking the basket and you should hear water.
Nov 12, 2012 | Whirlpool LSR6232J Top Load Washer
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
Basket rocks loudly during spin cycle. Does it on every load so I don't think it is a balance problem.
i just got a used whirlpool washer and as soon as it went on the spin cycle it started shaking bad! i adjusted the legs and moved the clothes around evenly! still doing it?? i would like some advice please!!!!!!!!!!
Mar 13, 2010 | Maytag Washing Machines
Basket is off balance. Basket is tilted (not
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 16, 2009 | Washing Machines
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose''
you more than likely have a broken tripod leg on the metal basket inside, when it goes into the spin cycle the basket become un balanced and is rubbing on the inside of the front outer tub which is the sandy grey stuff you are seeing.
if its less than 10 years old it should be in warranty and you can have a whirlpool repairman fix it, you would just be reponsible for the labor, which will cost around 300
if you decide to fix it yourself, first take off the bottm panel on the front of the washer, and clean out the drain pump. (i found the cause of my problem in there, and to get the rest of the plastic shavings out. 2screws came off one of the legs of the tripod of the metal basket on mine). next you will want to take it apart, so that you can see the back side of the metal basket, (i suggest taking the shocks off the front and back of the tub asselmbly before as soon as you can get to them, they can break pretty easy.) one of the legs you will find ir broken, corroded, or missing screws.
if you have to replace any parts, the front outer tub is about 100, metal basket is 200, and shocks are 15 a piece at appliancezone.com
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer is off balance.
My wife and I just purchased the Whirlpool 9400 series washer and dryer. We loved the pair, the installers came in and set them up ran them rather quickly and showed us the features and left. We put our first load into the washer, I will add, it was a rather large load, but nothing bigger than what the washing machine would handle. Started the washer up and walked away. About 30 minutes later we walk back into the laundry room to see and hear the washer rocking the pedastle door right out of the pedastle and then started to walk itself about 12 inches from the wall. This was very dangerous to us as we have a 14mth old. We immediatly called the store who sent another installer over. He again checked it for levelness and said that this is a known issue and that we should consider buying the cabrio or taking the washer and dryer off the pedastles.
So, to solve this issue, I'm sure you are all waiting. Infact, the washer was level, however, and this is what I found to be key, Lift the washing machine off the front legs, raise them up about a 1/4" higher than the back legs, this will make the washer uneven from front to back, but the other key is to make sure that the nut on the washer leg is all the way up and tight against the washer. In my user manual it said use a 17mm open end wrench to lock the nut against the washer, but my nut was a 14mm.
Again, make the front of the washer a little higher than the back and make sure all the nuts that are on the washer legs are tight against the washer or pedastle.
My washer went from the house ********, to the thing that doesn't make any noise at all.
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II Washer wont balance
Your basket drive is grabbing. the only way to stop that is to locate the clutch and the tube directly above it is your basket drive put a little white lithium up there. but not in the clutch. this will solve that problem. But if you do not know what you are looking for this will be difficult to locate.
Jan 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Home Logo
85 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
