Question about Acer TravelMate 290 Notebook
No power when at switch on
Acer 290 . Power from the charger is going through the charger cable before it connects to the computer, I checked this with a multimeter. At this point none of the 3 front lights come on. Blank screen also. No Sound Dead Post mortem required any ideas anyone for resurection? Gerry
    Scholar:
  • 181 Answers
Sounds like the power socket on the laptop may have broken loose from the board. Very common. If you have a multimeter, try and check the voltage ont the tines where the main battery receives it's charge, with the ac adapter connected to the laptop. That will tell a lot. Good luck
Posted on Jul 25, 2007
No power laptop
In this case first things you can do is check your Charger and the power cable, are they ok, is your charger providing proper voltage? Remove the battery and try switching on the laptop connecting charger only. if still same thing then i am afraid that there is some problem with *********** board.
Aug 14, 2012 | Acer Aspire 5742G
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
Acer 5315, no power on battery or power lead, charger light is on the charger, no lights on the computer.
Try a mains (ATX) reset.
- Remove power lead and battery.
- Press and hold the power button for 20 seconds.
- Replace power cable only.
- Test.
Failing this, you'll need to try and swap test your charger for another, to see if it might just be that.
Apr 26, 2011 | Acer Aspire 5315 Notebook
I have acer travelmate 290 while working suddenly the screen went white and the remained so i turned it off and now i try to start it power comes on but display shows nothing. tried removing HD and Drive...
I have the exact same problem with my old computer! The problem started after I switched the HDD a long time ago but I never got it (semi-)working again until a few days ago.I completely disassembled the computer and reassembled it again and I finally got something on the screen. I the tried to install win xp but when I pressed the keyboard the problem reoccurred. Therefore I'm fairly sure there is a short circuit or a bad connection somewhere probably on the underside of the motherboard close to the power supply DC-connector.
Apr 10, 2010 | Acer TravelMate 290 Notebook
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
My acer 4720z will not turn on anymore and it been
Dear, Remove the battery and plug-in the power cable to the laptop and then start it. If it do start, then there is a problem with battery.
I m sure your laptop is under warranty. Please go to service center.
cheers
Jan 29, 2010 | Acer Aspire 4720 Notebook
Laptop wont turn on while connected through cable, tries using another acer cable but still nothing. please if someone has any ideas let me know. thanks!
just check your laptop battery remove the battery once for 2 min
if this will not help try
step 2 check your Acer Laptop charger pin
roll the pin of your charger about 90 - 180 degree after attaching into
your laptop if it works then you have to contact your nearby service
center to alignment power jack of your laptop that attached to the
motherboard.
hope this can help you
if not
contact me with full details like
after attaching the power pin did you find any power light yes / no
did your charger show any light indicator yes / no
thanks
with regards
Dheeraj Singh Pundir
Nov 13, 2009 | Acer Computers & Internet
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Charger is no longer working
Oh, believe it or not. My computer use to do the same thing all the time. Just take the prongs on the plugin and bend them outwards slowly. This will make a tighter fit in the outlet.
Jun 11, 2009 | Acer Aspire 7720-4428 Notebook PC
My laptop is hanging when i switch on. please give me ideas tha will reciver my laptop. laptop model: acer travelmate 290
OK people, I have this old acer 290 the battery refuses to charge so I use the power adapter but when I swith it on it may quickly flash on and then hang, turns completely off dead as a door nail. this happened all the time untill one day I left the battery out of it plugged the power adapter in and the problem dissapeared. I have not yet replaced the battery so dont know if a new battery will solve the problem when reinstalled?
Jan 25, 2009 | Acer TravelMate 290 Notebook
Acer TravelMate 290 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
