Question about HP LaserJet 3050 All-In-One Printer
Scanned docs are too light
How do I change the settings on my HP Laserjedt 3055 to "darken" the scanned pages. In the current setting they are too light to be read.
  • jnoble Feb 11, 2009
    scanned documents are too light. How do you darken?
  • 40 Answers
Hi.
On some printers there is a "save" mode with the purpose of saving
ink or toner that if "on" will result in light printing.
Also see to that the scanner is scanning it with the right light/dark setting so that you know the picture has correct darkness and contrast to start with.
Hope this will help you.
Have a great day..
/Tech5508
Posted on Feb 13, 2009
The scans with my HP 1312 are very light and washed out. Is there a way to change the settings to darken the scans? i can darken the faxing and copying, but can't seem to find how to do darken scans.
Access the seocndary service on the printerand run a scan calibration, hit Setup once, press left arrow and cancel for 2 seconds, release, hit set up again.. that will get you to the secondary service.... just look for scan calibration and run each mode once
Aug 18, 2010 | HP LaserJet CM1312 All-In-One Printer
Have a printer/scanner that does not scan the documents in the same order they are scanned in...it changes them from the least amount of pages to the most....want to set up to keep the same as scanned...
are you scanning to email or folder ? what are you viewing the scanned docs with ? it sounds more with what you are viewing the docs with look for header of date and click it it should be newest to oldest date.
May 24, 2010 | Ricoh Aficio 2027 Black and White Copier
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Cheers
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
HOW TO SET FAX IN HP LESERJET PRINTER 3055
Pages 67 thru 117 covers all fax functions and features of your HP Laserjet 3055 in this users guide. Hope this helps.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Oct 24, 2009 | HP LaserJet 3055 All-In-One Printer
I am having prob with ma HP laser Jet 3055
firstly restart the printer and put the blue wire into the red pocket vice versa it should work
Aug 13, 2009 | HP Office Equipment & Supplies
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
HP LaserJet 3050 All-In-One Printer Logo
1,076 people viewed this question
Ben Johnson
