Question about Dell 1815dn All-In-One Laser Printer
Printer is saying scanner is locked, unlock scanner
How do i unlock the scanner
    New Friend:
  • 35 Answers
In the section where the paper exits the printer, there is a blue latch. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, The scanning unit assemply needs replaced...or the printer itselft which ever is cheaper.
Posted on Jan 30, 2009
Samsung sl-m2875fw says scanner locked
Try unlocking the scanner!
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK.
May 29, 2014 | Samsung Office Equipment & Supplies
Display says Scanner locked
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
Apr 26, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Printer says to unlock scanner
to unlock scanner this is a little lock where the copy come out. this is located on top this is a blue lock to your left side
Feb 22, 2010 | Dell 1600n All-In-One Laser Printer
Samsung scx4521f saying scanner locked
under the operations panel, where the copies comes out there is an optic lock. You need to unlock it.
Sep 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Scanner locked
There should be a lock icon either on the side of your scanner or underneath the bed look for it and make sure its unlocked.
Mar 29, 2009 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Error on printer
There is a safety lock on the scanner that may be in the locked position. Turn the unit off and locate the green lock lever/switch under the scanner where the paper comes out. It will be labeled with a icon (picture) of a lock (unlocked and locked). Move it to the unlocked and locked position multiple times, ending up in the unlocked position. It may be stuck so moving it back and forth may release it. Turn it back on and try it.
Mar 17, 2008 | Office Equipment & Supplies
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Dell 1815dn All-In-One Laser Printer Logo
1,063 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
