Question about Plumbing
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
  • 33 Answers
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Posted on Jan 29, 2009
Call Franke Consumer products 18006265771
I think I have a different model and comments below apply to that. Franke was VERY helpful and solved my problem.
Franke 900 strainer basket (903) is same as LIRA 008445. I could not find just replacement strainer and every website or plumbing store said I had to replace strainer and sink assembly. Franke sent me just a new strainer for about 1/4 cost of new assembly. Rubber seal on basket had worn and sink would slowly leak water.
Posted on Oct 10, 2012
Where can I purchase replacement insulation for the bottom of my Franke kitchen sink
You need to call the manufacturer or one of the distributors of your product. We do not have local information so we can't be of much help except what I said above..
Nov 07, 2012 | Franke CPX-110 Compact Undermount...
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
I need to find replacement white rubber feet for my Kohler sink basin rack,
Call Kohler Plumbing customer service: 1.800.456.4537, choose option 2 for service parts.
Tell them you need a "Feet Replacement Kit" for whatever model name/number and color your basement rack is. Prices run about $1 per piece plus shipping.
Feb 12, 2011 | Kohler K-8803-VS Duostrainer sink basket...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Sink Basket leaks and cant be removed cause of silicon adhesive
steady pressure from under the underside of the sink should cause the silicone to flex and eventually release.
You might also try some caulking remover available ot hardware stores. It's a product that comes in a tube and eases the removal of caulking products.
Be sure to look at the label for cautions and materials that it is safe to use it on.
Oct 07, 2009 | Belle Foret BF-NBBS2-CP Junior Basket...
What is the difference between franke sink and
It's what some contractor likes. If you find a sink that you like, buy it. ANY decent contractor can easily and successfully mount ANY sink.
Aug 09, 2009 | Moen 22119 - Commercial Stainless Steel...
Rust around the drain in the larger of the two sinks
You will need to reset the basket strainer using plumbers putty. Is there a garbage disposal installed? You will need to remove it to get to the basket strainer.
Mar 31, 2009 | Franke VNX-120-45 Vision Double Bowl...
Franke overflow waste connection
Once that fitting is damaged it is very difficult to repair. Try contacting Franke for nearest distributer and see if they will replace.
Mar 25, 2009 | Franke PAX-170 Papillon Undermount...
Plumbing Logo
978 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
