Question about Jenn-Air JED8430 Electric Cooktop
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red stripe, White is with the coiled silver wire, and the green is with the black on black. We are concerned about the green.
We have a jennair cooktop and we had to replace the top. we don't have the wiring diagram and want to make sure we wire it right. we have black and white coming in and we have black, red, and white on the cooktop. how do we wire it together?
Posted on Jan 31, 2009
    President:
  • 1,214 Answers
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Posted on Jan 28, 2009
Electrical wiring
ones connecting to anther set of plugs red on postive top countuins sending power to next box in a chain
Jan 19, 2008 | Jenn-Air JED8430 Electric Cooktop
Installing Jenn-Air cooktop, model jed8430
Hi, W/D here.
The plenum is the box the blower assembly attaches to. The blower pulls the cooking vapors down the plenum (well) and discharges through the duct.
Best regards, W/D
Aug 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Just installed a new Jenn-Air Model JED8430. Burners work well but fan will not turn on. Two black wires and a ground coming out of my wall....presumedley no neutral. Any suggestions
I suspect that the two black wires were attached to a wall switch or a wall times, along with the ground.
Check to see if you have a hot wire there. then temporarily wire the two black wires together and see if the fan comes on, i believe it will.
Jun 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-air JED8430 cooktop
Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
Dec 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Wire for stove top burners
same place you got the switches,you can usually get the whole harness.
Nov 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
JED8430 Fan Burning
great love it when people do this just commom sense most of the time
Dec 28, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
387 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
