Question about APC (0386-8)
Apc battery backup
About 2 or 3 times a day, the battery starts beeping for a minute or so
  • 84 Answers
You probably have a bad battery. It's also possible that you have a very bad energy supplier. But most likely the battery is on it's last leg.
Posted on Jul 25, 2007
HOW DO I KEEP MY MINUTE MAN BACKUP TO STOP BEEPING?
If you connect it up to a Windows computer with the supplied (goofy-looking) USB cable and install the APC Monitor progam "Powerchute" available on the APC web site, you can set all the activity levels and tell it just when to beep the beeper, or turn it off completely. I have two of these in my house, and have set them to never beep. The cable is goofy because it is USB on one end and a network-type on the other end.
Software Firmware
Jun 28, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
Why does my APC Conext UPS beep after power is restored?
After about 2 to 3 years the batteries usually have to be replaced. I found with our UPS's we get about 3 years maximum from the batteries. Ordering the originals from APC is rather expensive.
Locate a professional battery distributor in your area. Get the part numbers written on the batteries in your UPS, and including the detailed descriptions. You can then order these from the distributor. APC uses industry standard batteries. We found the Panasonic and Portilac brands to be excellent.
APC manufactures the UPS's. They use various battery manufactures depending on bid costing.
Jerry G.
Jun 29, 2012 | APC Conext UPS System
I have an APC XS 900 for about 1 1/2 now. I started getting a continuous beep with the overload light turning on. I could not get it to stop, even when the computer was disconnected. After reading the...
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | APC Back-UPS XS900 (BX900) UPS System
It's an older unit that i just tried. When i plug
Try installing the software that is included with the unit. If you didn't get the software, I believe you can download it for free from APC's website. The software will typically give you the status of the batteries and let you know if you need to replace them. If you can't get the software, take the batteries out (keep note of the wiring configuration) and test each battery using a DC voltmeter. The batteries should read around 13.5 volts DC. If they are around or below 11.5v DC, it's time for new batteries. This model, if its the black 110v version, requires the RBC32 which can be found at: http://www.batteryinternational.com/apc-rbc32--f2.html
Good luck and I hope I could help.
Jun 27, 2009 | APC Back-UPS RS Battery Backup (apw...
Beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Jun 20, 2009 | APC VS 500VA (VS500VA) UPS System
Erratic beeping
This is a signal that the battery is dying, and is failing the self-test. According to Conext, the battery replacement alarm goes off for one minute every five hours. You should also see the replace battery light on the front of the unit lit. Changing the battery should solve your problem.
Jan 01, 2009 | APC Conext 900VA (cnb900) UPS System
APC (0386-8) Logo
145 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
