Question about Garden
Blade removel any suggestions on how to remove blade cylinder 4 sharpening .cheers
2 Suggested Answers
rwvanlue
  • 375 Answers
SOURCE: how do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Posted on Nov 12, 2009
  • 332 Answers
SOURCE: How to remove deck on 1045 cub cadet to remove and
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Posted on Mar 30, 2010
How do I get the blade off my suffolk pUNCH ELECTRIC 12MOWER
Some of those blades are hard to get off. I put vice grips on the blade to hold it against the frame and put my long extension on my socket and sometimes put a pipe on to give me more pressure.
Just don't put too much pressure on to break something.
Mar 08, 2015 | Electric Garden
Procedure for removing spindle blades for sharpening
The blades on the spindle do not require sharpening. It is the single blade at the base of the lawnmower that requires sharpening.
Feb 09, 2015 | Garden
How do i remove the cutting blade from a morrison 500 reel mower
Disconnect spark plug wire. Turn on side. Block blade from moving using a block of wood. Loosen blade blot with appropate wrench or hindge handle(breaker bar) and socket.
Oct 19, 2014 | Garden
Wanted 14" cutting blade for Hovermaster GX635/c
I would suggest having your old blade sharpened.
Nov 16, 2012 | Garden
Can i sharpen chain
Yes, you can do it with a hand file or if you need to sharpen them often I would suggest an electric sharpener. There are models you can mount to your chainsaw or remove your chain and use a bench mounted sharpener. I would suggest looking at www.sharpchain.com for your sharpening solutions.
Nov 10, 2012 | Black & Decker Alligator Electric Lopper
I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
May 02, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
How to remove deck on 1045 cub cadet to remove and sharpen blades
Mar 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i sharpen cylinder mower blades
Nov 12, 2009 | Garden
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
102 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
