Question about Toshiba PDR-3320 Digital Camera
Lens not moving
I'm having a problem with my 3320 digital camera not adjusting the focus. Whenever I turn the camera ON, the camera comes ON but the lens does not come out causing blurred pictures. When using the T & W buttons, I can hear noise from within the camera but nothing is moving. When taking a picture, it takes a little longer for the camera to actually take the picture and I hear a beep beep noise. I tried removing the batteries and reinserting them and cycling the power on the camera but nothing worked.
  • nikolens Nov 16, 2007
    I have a nikon coolpix P3 , I have bought is just 5 months back and yesterday when I switched it ON the lens did not come out neither their was any picture on the screen. The lens did not open UP.
    So please help me .
    The camera gets ON. A beep is herd when I turn On the camera but the lens does not open.
  • jevon mack May 12, 2008
    yes my lens is not moving I get lens error and some numbers 1.211.111 somethin to that my wedding is soon and I cant afford a new camera I purchase it at Macy's can I get it replaced
My kodak dropped and I am getting lens error 1.122.111 something to that, I need it to work I purchased it at macys help can it be fixed
Posted on May 12, 2008
I shake my camera of hit it on the side a couple of times and it works just fine after that.
Posted on Aug 16, 2007
    Genius:
  • 2,985 Answers
The lens mechanism is shot. Depending on the age and possible cause of the condition- has it been dropped? I would think replacing the camera is a better option than trying to get it repaired -which I think is not a likely option
Posted on Jul 25, 2007
How do I use my old manual lense with a K200D?
Move the automatic/manual focus switch (on the lower right of the lens mount as you look into the lens) to manual. Focus manually by turning the focus adjustment on the lens itself - align the split image as you would with your old camera and take the picture.
(Use a handheld light meter and set the f/stop and shutter speed appropriately - the K200D doesn't have a visible meter. I would recommend bracketing your exposures -up a stop and down a stop from the 'appropriate' stop.)
Aug 11, 2013 | Pentax K200D Digital Camera with 18-55mm...
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
My lens will not focus. Pictures are all coming out blurry no matter what setting I have the camera on, and no matter how much I zoom in or nout.
Hi
You know sometimes the lens will not focus if you have a physical damage etc., first of all i would like to clarify some points.
1. Did you place your camera near to a strong magnetic area?
2. Did you drop the camera?
3. Did you use Zoom in Zoom-out continuously at the same time?
for the first point i am sure it was exposed to strong Magnetic field, as and when it is exposed the coil of the zoom lens which move the lens in and out will get out of place and makes it impossible to maintain focus. If so then better is to open the camera and re-adjust the lens. But if you are confident to put it back then open it or try to slowly wiggle the camera and check if it gets better.
Jul 18, 2011 | Kodak EasyShare Z915 Digital Camera
Camera won't focus
I think you're camera has had it. You could try the Toshiba web site follow links for support and downloads to see if there's a firmware upgrade which may solve the issue.
I've checked the specifications and I wouldn't spend anything on repairing it. I'm afraid its just not worth the outlay. You could probably get a good camera with a higher specification second hand for less than an hours repair bill.
Jul 19, 2010 | Toshiba PDR-3320 Digital Camera
First thing do you charge for this if so i can not do it When looking through the camera lens to take a shot it is bluery and you can not tell what it is. toshiba PDR 3320 digital still camera
No charge.... FREE!
The eyepiece has no diopter setting.
However, if you press the shutter button "halfway" down (don't press it all the way). the picture will come into focus.
After you focus, then press the shutter button all the way down.
This will work...
Sep 08, 2009 | Toshiba PDR-3320 Digital Camera
Zoom Error?
Dirt in the focus motor drive gears right behind the lens at the front.
It's a **** design (my opinion). The lens at the front moves in and out depending on your zoom level. It can come right out of the lens barrell at the front. So, if it can come out, dirt can get in. and it's a pig to clean out and reset. Bin it or sell for parts.
Jan 25, 2009 | Fuji FinePix A500 Digital Camera
Problems with Auto Focus on Nikon D100
You can adjust the number of focus areas so that it will not try to compensate for many objects in the pic at 1 time
Aug 14, 2008 | Nikon D100 Digital Camera
My Olympus 740 digital camera does not auto focus any more. I can make it focus for the most part by zooming in, but is there anything I can do to make it start up focused? I had another Olympus camera...
Take it off manual focus? There may be an "all reset" option in one of the menus that makes the camera factory default whenever its turned on, usually this is full auto mode. If the camera will only focus when the zoom is used, there may be a secondary lens inside the lens barrel that is not moving as it should. Time to service it if that is the case.
Jul 07, 2008 | Olympus Cameras
Locked lens
your camera needs a new lens assembly.These lenses are not repairable .They can only be replaced.
Jun 23, 2008 | Toshiba PDR-3320 Digital Camera
Repair lens
Needs a clean perhaps - grit ingress - repair shop -will be expensive - of course
Feb 27, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Toshiba PDR-3320 Digital Camera Logo
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Simon Flummox
Simon Flummox
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
