Question about Harman Kardon AVR 25 MKII
Static and popping from Harmon Kardon AVR 340
ONE month out of warranty, I began hearing constant static and occasional static popping from my right front speaker. I though I had blown the tweeter, but when I plugged in the left front speaker to the right front output of the $600 HK AVR, the same static was now in the left speaker. Thus, it was not the speaker. Both Circuit City and the HK authorized service center confirmed the problem. HK graciously authorized a courtesy repair to no avail – three months at the shop and I got the problem back. Has anyone had this problem resolved short of a getting a refurbished replacement (garbage) from HK? Should I just give up, buy the Denon, and lesson learned?
  • 34 Answers
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Posted on Jan 29, 2009
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
MX-450 universal remote code for AVR-354
Harm an / Kardon 0 0 8 1 ,0 0 3 8
Sep 14, 2009 | Televison & Video
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I PURCHASED FROM ABC WAREHOUSE HARMAN/KARDON AVR 340.ITS A FLOOR MODEL SOLD AS IS WITH OUT OWNERS MANUAL AND REMOTE.I REALLY NEEDA OWNERS MANUAL.CAN YOU HELP ME GET ONE?
Harmon Kardon AVR340 just has no sound and it doesn't pass the video through. Looks normal when on. ( Display shows everything is on)
Aug 26, 2008 | Harman Kardon Audio Players & Recorders
573 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
