Question about Mitsubishi WS-65809 65" Rear Projection Television
Removing and cleaning the screen on a 65" rear projection tv
How to clean cob webs out of the inside screen of a 65" tv and removing the screen? thank you
    Problem Solver:
  • 4 Answers
You can remove the screen, take the speaker cover off in the front you sould be able to see the screws that hold the screen on the bottom remove the screws and unplug the wire the goes to the screen fron the tv, you need two people one on each side just pop each side up about an inch and pull it off,
Posted on Feb 16, 2009
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
I have cob webs behind the screen. i have tried vacuming and blowing to no avail. can I some how remove the screen to clean it ?
remove rear cover---get a swiffer cleaner and gently from rear of set that is not plugged in reach in and wipe all the webs away--do not apply force to inside of screen---really no reason to remove entire front screen for this "repair".
Apr 16, 2012 | Panasonic Televison & Video
HI I HAVE A SPIDER WEB IN MY TV HOW CAN I GET RID OF IT . IT REALLY BOTHERS ME WHEN I WATCH TV BECAUSE I CAN SEE IT
try to open the back of your tv but be sure to unplug it then clean the projector lens using a dry cloth cotton.
Oct 15, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
I have cob webs on the inside of screen. How do I open up to clean them out?
Unplug the TV. Take the back off. Using a broom or duster with a long handle, get the cob web inside the TV. Make it sure not to push the screen out. Good luck!
Apr 10, 2010 | Sony KP-51WS510 51" Rear Projection...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Needs to be cleaned
The back comes off the unit.  Lots of screws.  If you do this, DO NOT touch anything related to the tubes.  Power it off for several hours...unplugged...before touching it.
Nov 23, 2008 | RCA P46924 46" Rear Projection Television
Cob web
The cob web is likely to be on the other side of the screen. I undid the back cover and dusted the screen from the inside. I also sprayed pesticide inside the TV (wood and corners only!)
Mar 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Cob webs
Hi, remove rear top cover, this will give you access to clean the unit, be advised you should use 2 people once you get all the screws out, the back is HEAVY because there is a mirror attatched to the rear cover(on the inside) and if you drop the cover it`s expensive to replace, good luck, BMW Rider
Jan 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi 53UDX 10B 53in Rear Projection
Steve, easier and safer to remove back panels, remove bottom back cover then remove top back cover, be advised the top cover has a giant mirror on the inside so it will be heavy and easy to break, use 2 people to remove it, this way you can get at the inside and clean the mirror at the same time, hope this helps and Happy New Year, BMW Rider
Dec 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
261 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
