Question about KitchenAid KUDC25CH Dishwasher
Kitchaide Dishwash Door
I have a kitchenaird dishwasher and something has broken on the door. When I open it, the door (due to it's weight) falls quickly down.
  • Anonymous Mar 16, 2014
    kitchenaid dishwasher door falls straight down
  • 51 Answers
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Posted on Jul 25, 2007
Why does my dishwasher door fall freely when opened?
There are springs and pulleys that assist the door. They use a nylon rope that is very thin to connect the pulleys door and springs. The rope is most likely broken.
Jan 10, 2016 | Dishwashers
How can I adjust the weight on the integrated door
there are springs with cables in most dishwashers i never had that problem but i did replace one spring that had broken. making it fall to fast. its no to hard if your handy. most appliance parts stors if there good should be able to help if they can be adjusted
. Contact Us - Kenmore
http://www.kenmore.com/customer-care/nb-100000000410025
not sure why but i can,t see brand of your dishwasher
Mar 08, 2015 | Dishwashers
The door of the dishwasher just falls down with the weight
The springs/strings, and whatever else supports the weight of the door are broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
May 05, 2011 | Miele Dishwashers
Something has happened to the door of my dishwasher when you open it it falls down heavily and now when I put the dishwasher on the door keeps opening
The door springs or ropes have broken...
heatman101
Mar 16, 2011 | Dishwashers
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
How do I adjust the door of the dishwasher so that it doesn't fall completely open
There is a T20 screw located above the tub (open door to view) toward the left side. Tighten this screw a turn at a time, testing the apparrent door weight between turns until the door is neutral.
http://www.mieleusa.com/manuals_pdf/Residential/Dishwashers/English_manuals/Installation_Instructions/Full_Integrated_install.pdf
Jul 10, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwasher does not "pause" (hault) when I open the door
it's the door switch gone bad or the wire going to it has fallen off.
Mar 01, 2007 | Asko D1776 Built-in Dishwasher
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
539 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
